It is currently Jan Sun 16, 2022 11:49 pm
 Post subject: Silvertone 1066 100.202 needle
PostPosted: May Wed 03, 2017 12:49 am
Hey guys! First time posting on here... A buddy told me I needed to check y'all out so here I am!
Anyways.. I have a Silvertone 1066 100.202 that I just picked up and I am in need of a needle/cartridge for it. I've been searching everywhere online and I did do a quick sure on here and I couldn't come up with anything. So I was wondering if someone knew which one I need and where I could get one!
Thanks!
 Post subject: Re: Silvertone 1066 100.202 needle
PostPosted: May Wed 03, 2017 2:25 am
Do you have the original cartridge to post a pic?
PostPosted: May Fri 05, 2017 6:28 am
I do!
PostPosted: May Fri 05, 2017 2:25 pm
That's an Astatic 51 cartridge. It takes a 152 series Pfanstiehl needle.
http://www.thevoiceofmusic.com/catalog/ ... ategories=
These cartridges are often still good as found, as long as the little metal fork that holds the stylus in place isn't broken or damaged.
If you need a new cartridge, the Astatic 51 is out of production and they're pretty much all gone. Pfanstiehl makes a P-51 cartridge designed to replace it, but you will need to change out the clips on the wires because the P-51 has round pins rather than flat ones.
PostPosted: May Sat 06, 2017 7:57 pm
Awesome! Thanks for the help!
PostPosted: Sep Tue 14, 2021 5:13 pm
Hey there, if you still see these updates can you take some pics of your system? I have obtained this one and wish to restore it but I do not know what the face plate or knobs look like. Please post some pics so that I can fix this one up.
Thanks a lot!
