It is currently Aug Sat 13, 2022 8:58 pm
 Post subject: Magnavox micromatic vinyl player does not spin
PostPosted: May Sat 21, 2022 2:14 am
Hi,
I am trying to restore an old magnavox console and I have a micromatic vinyl player that goes with it. The issue is the vinyl player doesnt spin. After some work I could get this to work partially. Its not an electrical issue but a mechanical issue and the old grease needs to be cleaned. I was thinking of using WD40 instead of alcohol. I cant find phono-lube but would "Super Lube-21030 Synthetic Multi-Purpose Grease" be good enough and Zoom oil. I presume I use grease where things slide and oil for everything else because the manual doesn't really say what parts need oil or grease.
I also noticed that the springs have lost their strength. Its possible the grime doesn't make them work well but how do I replace these springs if I need to or is there a way to reuse them?.
Noel
 Post subject: Re: Magnavox micromatic vinyl player does not spin
PostPosted: May Sat 21, 2022 10:15 pm
Here is post number seven of a 21 post thread that goes into great detail of record player servicing.
British terminology used.
https://www.vintage-radio.net/forum/sho ... ostcount=7
Thread: Reviving your old record player.
https://www.vintage-radio.net/forum/sho ... post472395
I sent you a PM (private message) last week, May 14
It contained links to good information.
Post New Topic Post Reply  [ 2 posts ]  Moderator: Alan Voorhees
