My problem was mostly figuring out the service manual and how each part is supposed to work and what each sentence means. The end result was a fiber washer (Looks like old fashion flat cork.) had broken in half and had fallen out of the Tone Arm Clutch Assy. I slide it back in, but one piece kept falling out. I adjusted the clamp screw to hold just one piece which through off the angle (Blue) of these two parts. I finally realized if not perpendicular then the top pin wasn’t going into the main gear outside groove at the end of the cycle. Somehow I got them both straight with enough pressure to hold that washer piece in place. Now it cycles through each record and sets back in the rest post at the end. For over a week now I would say it’s going back in a box tomorrow and the next day I was back to the service manual trying something else. Working on these players takes a lot of hands on experience because the important moving parts are hidden by this and that assembly.
Freeman
