It is currently Feb Wed 26, 2020 4:42 am
 Post subject: What Schematic To Use.?
PostPosted: Dec Mon 05, 2011 3:50 pm
I now have two Zenith TransOceans and they are both of the 500 series. My question is, how do I know which schematic to use.?
I presently have Sams 152-12,Ryder G500 and one titled Model H500, Chassis 5H40.
 Post subject: Re: What Schematic To Use.?
PostPosted: Dec Mon 05, 2011 4:36 pm
Does your set have a chassis number?
PostPosted: Dec Mon 05, 2011 6:41 pm
cwtravis
My mistake, hard to have anyone help me without supplying the proper info. I supplied the spealer numbers if needed
1st Radio
Chassis 244333
Speaker 343217
2nd Radio
Chassis 2276759
Speaker 343300
Gerry
PostPosted: Dec Mon 05, 2011 6:57 pm
The G500 is easy, it's in Sam's 83-16. The H500 is a little more difficult. There were five chassis variations of which I have three so far. There are not diagrams readily available for all. Start with the Sam's 152-12 and compare it with your chassis. If different, post the differences here on the forum to see if anyone has the same version with a schematic.
Pat
PostPosted: Dec Mon 05, 2011 7:42 pm
Pat
Of the two chassis numbers I listed which one is for the G500.?
Gerry
PostPosted: Dec Mon 05, 2011 8:39 pm
G500 should have chassis no. 5G40.
PostPosted: Dec Tue 06, 2011 4:07 am
Were do I find the number 5G40 on the the radio.? I looked everywere and was unable to
find it.
Gerry
PostPosted: Dec Tue 06, 2011 4:13 am
Have you checked here for schematics and service data?
http://www.transoceanic.nostalgiaair.org/
PostPosted: Dec Tue 06, 2011 3:33 pm
I have down loaded both schematics and am reviewing them to see if I can identify which model they are.
Gerry
PostPosted: Dec Wed 07, 2011 12:26 am
find it.
Gerry
If you pull the chassis you should see a green or blue tag with the serial number. On the left side of the tag you should see the chassis number.
PostPosted: Dec Wed 07, 2011 2:47 am
I have all three of my TO chassis on the bench and I have looked on each of them for any tags. There are no tags on any of them.
Gerry
PostPosted: Dec Wed 07, 2011 4:04 am
chassis number will be stamped on the rear of the chassis. it may have faded. G500 chassis will have different dial than the H500 and will have a 1S5 instead of a 1U5 for the 1st audio tube. It will also have pin jacks on the back instead of a 1/4 " phone jack. Early H500 chassis will also have the 1S5 tube and the earliest will have the 2 pin jacks on the back instead of
a 1/4 " phone jack. Schematics are almost the same and altho the 1S5 and 1U5 have different pinouts, they are also the same tube. hope this helps. :-)
PostPosted: Dec Thu 08, 2011 10:14 pm
With the help of everyone who answer my question I have reviewed all the suggested and now know I have two H500.
Thanks Guys
Post New Topic Post Reply  [ 13 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: Google [Bot] and 18 guests
