Page 1 of 1
[ 14 posts ] |
Author |
togermano
Post subject: Screen Burn in... CRT monitor.... Posted: Jun Sat 23, 2012 3:57 pm |
Joined: Jan Mon 11, 2010 3:51 am Posts: 864 Location: Springfield,MASS
I bought a nice 20+ inch CRT monitor at a tag sale.... I bought it because i believe that they have better picture quallity over LCD..... Unfort the screen has ghosting image on it and burned into the screen.. Is there away of fixing this or should I just Shi* can it?
_________________ REOPENED JOIN TODAY http://www.retroelectronics.com
Top |
Rich, W3HWJ
Post subject: Re: Screen Burn in... CRT monitor.... Posted: Jun Sat 23, 2012 4:31 pm |
Joined: May Tue 30, 2006 4:46 pm Posts: 10411 Location: Santa Rosa, CA
The image is "etched" into the phosphor coating on the inside front of the CRT. No way to get at it or reverse it.
Sad.... that's why 'screen savers' were invented.
Top |
PaulC
Post subject: Re: Screen Burn in... CRT monitor.... Posted: Jun Sat 23, 2012 4:37 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 685 Location: Yardley, Pennsylvania
No way that I know of to fix screen burn. Back in the 80's I remember the computer swap meets and many venders had airport monitors with massive screen burn. You could see the flight names while it was sitting on the asphalt. Personally I don't miss CRT monitors one bit. And for picture quality the new LED backlit monitors are great.
Top |
35Z5
Post subject: Re: Screen Burn in... CRT monitor.... Posted: Jun Sat 23, 2012 4:39 pm |
Member |
You can try running it at a high brightness with a blank raster, that tends to "age" the unburned areas faster than the burned, but I doubt it will ever be perfect...
Top |
threeneurons
Post subject: Re: Screen Burn in... CRT monitor.... Posted: Jun Sat 23, 2012 5:32 pm |
Member |
Joined: Jul Sun 17, 2011 1:11 am Posts: 4529 Location: Tehachapi, CA - Bottom end of the Sierras
Back in the days of CRT terminals, all that could be displayed was text. Usually 25 lines tall, with 80 characters per line.  Always in the same location. The screen would get little rectangles burned into it in this 80 x 25 pattern. A tad more burnt along the left edge, since most used some sort of command line interface:  These terminals connected to some unseen mainframe, over a RS232 serial link, that transmitted the characters typed and displayed received characters onto the CRT. Early CP/M personal computers used the same style link. Most hobbyist couldn't afford a CRT terminal and often bought a used Teletype, which also second as a printer.
_________________ Life is like a roll of toilet paper - The closer you get the end, the faster it goes - A.E. Neuman
Top |
togermano
Post subject: Re: Screen Burn in... CRT monitor.... Posted: Jun Sat 23, 2012 5:51 pm |
Interesting info threeneurons I love hearing stories about computer back in the day ... I wish I lived back then Now its gonna be annoying to get rid of it.... I think once its night time i am gonna put the monitor on their front lawn
Top |
N7ZAL
Post subject: Re: Screen Burn in... CRT monitor.... Posted: Jun Sat 23, 2012 6:01 pm |
Member |
Joined: Jul Wed 21, 2010 11:04 pm Posts: 3025 Location: Roaming the West
Top |
35Z5
Post subject: Re: Screen Burn in... CRT monitor.... Posted: Jun Sat 23, 2012 8:36 pm |
Member |
threeneurons wrote: Back in the days of CRT terminals, all that could be displayed was text. Usually 25 lines tall, with 80 characters per line.  Always in the same location. The screen would get little rectangles burned into it in this 80 x 25 pattern. A tad more burnt along the left edge, since most used some sort of command line interface: Yeah I just repaired a couple IBM 5151 monitors, luckily neither are burned... Tom
Top |
Nick D.
Post subject: Re: Screen Burn in... CRT monitor.... Posted: Jun Sat 23, 2012 9:26 pm |
Member |
Joined: Jun Wed 01, 2011 9:05 am Posts: 7094 Location: "Amish Country", PA
Someone told me that you could lessen burn-in by swiping a magnet back and forth over the area, with video on the screen, in as many directions (incidental angles) as possible. This is a good oppurtunity to try it, since the screen is already not usable anyway....
_________________ Majestic - Crosley - Zenith ~CONSOLE FREAK~ Philco - American Bosch - RCA
Top |
N7ZAL
Post subject: Re: Screen Burn in... CRT monitor.... Posted: Jun Sat 23, 2012 9:35 pm |
Member |
Top |
Nick D.
Post subject: Re: Screen Burn in... CRT monitor.... Posted: Jun Sat 23, 2012 11:21 pm |
Member |
Yep.
Top |
threeneurons
Post subject: Re: Screen Burn in... CRT monitor.... Posted: Jun Sun 24, 2012 1:57 am |
Member |
Nick D. wrote: Someone told me that you could lessen burn-in by swiping a magnet back and forth over the area, with video on the screen, in as many directions (incidental angles)... You mean something like this:  Inexpensive rare earth magnets, and high resolution (if you consider VGA high resolution) got into the hands of the "kiddies" (you set the age bracket) just about the same time. We'd stick a magnet against somebodies monitor, and leave a big distorted color blob there. You could degauss it, by waving the same magnet back and forth, and move it backwards, away from the screen, with each swipe. Also, the whole screen would ripple, if there was a big linear supply nearby (big iron xfmr). Sometimes, you couldn't consciously see it, but with me, it relayed to info to my brain. My inner ear said otherwise, and it would make me queazy.
Top |
35Z5
Post subject: Re: Screen Burn in... CRT monitor.... Posted: Jun Sun 24, 2012 5:11 am |
Member |
Nick D. wrote: Someone told me that you could lessen burn-in by swiping a magnet back and forth over the area, with video on the screen, in as many directions (incidental angles) as possible. This is a good oppurtunity to try it, since the screen is already not usable anyway.... Ain't gonna happen, burned phosphor could care less about magnetism, all that's going to happen is screwed up purity that may require a manual degaussing coil to to correct... Tom
Top |
N7ZAL
Post subject: Re: Screen Burn in... CRT monitor.... Posted: Jun Sun 24, 2012 5:34 am |
Member |
Top |
Users browsing this forum: azenithnut, BobWeaver, Majestic-12 [Bot] and 29 guests |
