It is currently Jan Sat 23, 2021 11:02 am
 Post subject: Screen Burn in... CRT monitor....
PostPosted: Jun Sat 23, 2012 3:57 pm
I bought a nice 20+ inch CRT monitor at a tag sale.... I bought it because i believe that they have better picture quallity over LCD..... Unfort the screen has ghosting image on it and burned into the screen.. Is there away of fixing this or should I just Shi* can it?
REOPENED JOIN TODAY http://www.retroelectronics.com
 Post subject: Re: Screen Burn in... CRT monitor....
PostPosted: Jun Sat 23, 2012 4:31 pm
The image is "etched" into the phosphor coating on the inside front of the CRT. No way to get at it or reverse it.
Sad.... that's why 'screen savers' were invented.
PostPosted: Jun Sat 23, 2012 4:37 pm
No way that I know of to fix screen burn. Back in the 80's I remember the computer swap meets and many venders had airport monitors with massive screen burn. You could see the flight names while it was sitting on the asphalt. Personally I don't miss CRT monitors one bit. And for picture quality the new LED backlit monitors are great.
PostPosted: Jun Sat 23, 2012 4:39 pm
You can try running it at a high brightness with a blank raster, that tends to "age" the unburned areas faster than the burned, but I doubt it will ever be perfect...
PostPosted: Jun Sat 23, 2012 5:32 pm
Back in the days of CRT terminals, all that could be displayed was text. Usually 25 lines tall, with 80 characters per line.
Always in the same location. The screen would get little rectangles burned into it in this 80 x 25 pattern. A tad more burnt along the left edge, since most used some sort of command line interface:
These terminals connected to some unseen mainframe, over a RS232 serial link, that transmitted the characters typed and displayed received characters onto the CRT. Early CP/M personal computers used the same style link. Most hobbyist couldn't afford a CRT terminal and often bought a used Teletype, which also second as a printer.
Life is like a roll of toilet paper - The closer you get the end, the faster it goes - A.E. Neuman
PostPosted: Jun Sat 23, 2012 5:51 pm
Interesting info threeneurons I love hearing stories about computer back in the day ... I wish I lived back then
Now its gonna be annoying to get rid of it.... I think once its night time i am gonna put the monitor on their front lawn :lol:
PostPosted: Jun Sat 23, 2012 6:01 pm
The screen burn is what sparked the use of "screen savers." FYI
LAter, 73's
Bill N7ZAL
http://www.westernwoodartist.com
http://www.southwestwoodcrafts.com
PostPosted: Jun Sat 23, 2012 8:36 pm
Yeah I just repaired a couple IBM 5151 monitors, luckily neither are burned...
PostPosted: Jun Sat 23, 2012 9:26 pm
Someone told me that you could lessen burn-in by swiping a magnet back and forth over the area, with video on the screen, in
as many directions (incidental angles) as possible. This is a good oppurtunity to try it, since the screen is already not usable
anyway....
PostPosted: Jun Sat 23, 2012 9:35 pm
Then you might have to degauss it ?
LAter, 73's
Bill N7ZAL
PostPosted: Jun Sat 23, 2012 11:21 pm
Yep. :)
PostPosted: Jun Sun 24, 2012 1:57 am
as many directions (incidental angles)...
You mean something like this:
Inexpensive rare earth magnets, and high resolution (if you consider VGA high resolution) got into the hands of the "kiddies" (you set the age bracket) just about the same time. We'd stick a magnet against somebodies monitor, and leave a big distorted color blob there. You could degauss it, by waving the same magnet back and forth, and move it backwards, away from the screen, with each swipe.
Also, the whole screen would ripple, if there was a big linear supply nearby (big iron xfmr). Sometimes, you couldn't consciously see it, but with me, it relayed to info to my brain. My inner ear said otherwise, and it would make me queazy.
PostPosted: Jun Sun 24, 2012 5:11 am
anyway....
Ain't gonna happen, burned phosphor could care less about magnetism, all that's going to happen is screwed up purity that may require a manual degaussing coil to to correct...
PostPosted: Jun Sun 24, 2012 5:34 am
That is my thought also.....
LAter, 73's
Bill N7ZAL
Post New Topic Post Reply  [ 14 posts ]  Moderator: Alan Voorhees
Users browsing this forum: No registered users and 23 guests
