It is currently May Thu 28, 2020 4:16 pm
Post New Topic Post Reply  [ 99 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: Philco 48-1000 Extreme Cabinet Restoration
PostPosted: Sep Thu 15, 2016 11:11 pm
See this thread - http://antiqueradios.com/forums/viewtopic.php?f=3&t=269342 - for my 1.5 year project (so far) to restore my grandfather's 1948 Philco 48-1000 TV, which was stored in a puddle in a garage for 50 years. It is electronically working now, more or less, and I'm moving on to the cabinet, hence a new thread here in the Cabinet Restoration forum. Below are some pictures of the cabinet, when I got it and in its current, less-assembled state.
File comment: As received.
File comment: Insides were a mess.
File comment: Cabinet as it is today.
I want to keep as many original pieces as possible, so I'm trying to avoid replacing all the bad wood.
My plan is:
- clean the spaces between the wood as best I can - q-tips, forced air
- use wood glue and clamps to "re-laminate" the split and warped wood
- use filler and new screw holes to restore the structural integrity on the warped parts
- tighten up screws all over
- strip the old finish with Minwax Antique Furniture Refinisher
- get new veneer and replace all missing sections
- stain
- paint (the bottom panels are/were black)
- re-finish with lacquer, maybe tinted amber
Any thoughts, opinions, insights, advice - all would be appreciated!
 Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration
PostPosted: Sep Fri 16, 2016 3:57 pm
Wow Steve, that's quite a project you're taking on, but I'm impressed that you are going for it. I have seen basket cases restored in the past and it's surprising what can be done. A google search may lead you to similar projects and good tips. When you get all the delamination re-glued it returns the rigidness to the cabinet and things don't look quite as bad. Good luck with it. I'm looking forward to seeing the set finished one day!
Joe
PostPosted: Sep Sun 25, 2016 11:48 pm
For the speaker grill, it seems it was painted gold? but not solid gold? The pictures I can find of a 48-1000 show a gold-coated speaker grill, but with much dark between the openings.
--> Does anyone know how the grill *should* be painted?
I'm thinking of using masking tape and then spray painting it the gold on the left:
I'd paint the trim line around the screen in the same gold - it was gold originally too. And the centers of the knobs too, which were gold.
What do you think?
PostPosted: Oct Wed 19, 2016 10:21 pm
I have one at home but that's not much help so here's a picture from Radiolaguy.
It appears the surface area is gold but the holes and crosshatches are not, also it's hard to find gold that matches the vintage stuff very well.
The knobs should have Brass inserts and will polish out nicely (unless they are missing).
Philco knobs should be fairly easy to locate if it comes to that.
PostPosted: Oct Sun 23, 2016 1:57 am
Thanks Eric. I've seen pictures like that of the original sets. I could not figure out how they painted it such that only the tops of the "pillows" on the speaker grill got paint, but not the inside of the holes or the crosshatches between them. In the end I just sprayed it gold. I may try some acrylic dark wash that I have in the crosshatches to see if it looks any more like the original. Note: the gold is not so bright and washed out as in the photo. It is a deeper richer gold, closer to, though not the same as, the original.
The other day I tried some Brasso on a knob and it came out real nice:
PostPosted: Oct Sun 23, 2016 1:59 am
For the final lacquer on the whole cabinet - satin or gloss finish?
PostPosted: Oct Sun 23, 2016 2:17 pm
I would go with semi gloss lacquer , 60-70 % shine.
PostPosted: Oct Sat 29, 2016 7:45 pm
I'm thinking of Mohawk brown mahogany (the middle color on my test board), perhaps with some clear/amber lacquer over that. The pictures I have of it, like the first pic below that I got off the internet, show a redish/orangish finish. I think the brown mahogany/amber combo would get close. Do you think that would replicate the original finish color?
PostPosted: Oct Mon 31, 2016 7:50 pm
it may not be origional but it looks so much better with the whole speaker grill painted gold i would leave it that way for sure. also i would probably paint the inside of the holes gold. yes i usually like everything original but in this case all gold looks much better.
PostPosted: Nov Fri 04, 2016 3:20 am
I've ordered Mahogany veneer. The plan is:
- Mohawk brown mahogany toned lacquer
- Amber lacquer over that
- base of tv black lacquer paint, gloss
- clear lacquer over everything
QUESTION: for polishing and such, I've heard that a gloss lacquer finish can be "rubbed out" so that it is nice and deep and original looking, not highly glossy. Is that what "Deluxing Compund", like from Behlen is for? How do you rub out the finish so that it is rich and warm and doesn't scream "i've just been refinished", and isn't full on mirror glossy?
PostPosted: Nov Fri 04, 2016 3:22 am
Another question - after I strip off the old finish, should I oil the old, probably dry wood? If so, with what?
PostPosted: Nov Fri 04, 2016 4:24 am
Third question - is minwax spray gloss lacquer good for the gloss coats (to seal before toned lacquer, then after the toned and amber lacquer to seal the whole thing up)? Or should I use Deft or a different brand? Which lacquer to you prefer?
PostPosted: Nov Fri 04, 2016 4:30 am
Here is a good view of the wood grain and finish (what's left of it) on the one good side of the cabinet. Does it look like Mahogany? I my brown mahogany toned lacquer + amber lacquer plan a likely match?
PostPosted: Nov Fri 04, 2016 8:31 pm
No, do not oil the wood. Yes, it appears to be mahogany. Stick with just the Brown Mahogany toner, no need to use amber over it. The amber color you're seeing is the old clear lacquer that has discolored with age.
I prefer to use Mohawk clear and toner lacquers.
Here are the basic steps to recreating a classic lacquer finish.
http://www.antiqueradios.com/features/lacquer.html
PostPosted: Nov Sat 05, 2016 1:32 am
Behold, the power of Brasso.
File comment: Before.
File comment: After.
PostPosted: Nov Sat 05, 2016 2:35 pm
Impressive! Nice work on those knobs.
PostPosted: Nov Sun 06, 2016 4:26 am
HELP - I can find no *defninitive* information on whether the veneer is walnut or mahogany. I have very firm answers from various sources on both. Does anyone know how I can tell for sure? Do you know anyone who would know for sure?
PostPosted: Nov Mon 07, 2016 6:10 pm
Wood type: That is hard to tell from those photos. It does not look like mahogany, but it does not look like walnut either. The grain resembles birch, but the color is not right for birch, so it could be yet another type of wood. To get a better idea, do this. Strip and sand a large section with fine sandpaper. Wet it with a damp sponge and immediately take pictures before it dries. Get close-ups and overall views of that area and post them here. You will get several opinions.
PostPosted: Nov Fri 25, 2016 4:13 am
Could it be rosewood? A friend of mine suggested that.
Did Philco or other TV manufacturers use that type of wood?
PostPosted: Nov Sat 26, 2016 3:43 am
Can not wait to see the finished project!
Post New Topic Post Reply  [ 99 posts ]  Moderator: Peter Go to page 1, 2, 3, 4, 5  Next
Users browsing this forum: poulsbobill and 3 guests
