It is currently Jan Sat 16, 2021 4:30 am
 Post subject: HP 436 power meter
PostPosted: Jan Thu 12, 2017 3:54 am
I've got the main unit, but need the cable and power head.
Question is whether it's worth investing in the power head and cable.
I bought one of these a while back and it's pretty accurate. Put it in this case with the freq counter.
http://www.ebay.com/itm/NEW-0-500Mhz-RF-Power-Meter-RF-power-Measurement-80-10-dBm-/262563218073?hash=item3d21fcc299:g:6Z0AAOSwZVlXo20g
All I am doing is occasional FM alignments.
 Post subject: Re: HP 436 power meter
PostPosted: Jan Thu 12, 2017 4:07 am
How would that be used for FM alignment?
PostPosted: Jan Thu 12, 2017 4:10 am
When adjusting the output power for the IF and rf signals of the signal generator?
PostPosted: Jan Thu 12, 2017 4:13 am
typically not necessary. Alignment is generally done using the lowest signal level that gives a usable output. In effect, the receiver is the power meter.
One benefit might be comparing different sets for sensitivity.
PostPosted: Jan Thu 12, 2017 4:21 am
While it may not be necessary, the question remains of whether the cost of a replacement power head and cable is worth it.
PostPosted: Jan Thu 12, 2017 5:01 am
Figure anywhere from $75 to $100 for a cable that isn't beat and intermittent, and anywhere from $200 to $600 for a sensor that still works. Don't even consider a sensor that hasn't been tested by somebody who knows what they are doing, or doesn't come with a right-of-return. RF power meter sensors are easily damaged by feeding too much power into them and once that happens, repairs are not cost effective. You don't want to end up with somebody else's mistake! Damaged sensors may still appear to work when connected to a meter, but sensitivity and accuracy won't be where they should be.
As for use in FM receiver alignments, it seems rather pointless. A power meter has to operate on a known impedance (e.g. 50 ohms) to give useful readings; this impedance seldom occurs in FM radios of the entertainment variety. Also, there is usually a certain minimum level such as -50 dBm below which the sensor simply doesn't read, and that level may still be too high for direct connection to an RF or IF stage in a receiver. One can always measure a higher level and then pad it down, but it's not clear what is being accomplished.
Users browsing this forum: rgbiker, Tom Bavis and 23 guests
