It is currently Dec Mon 09, 2019 12:04 am
 Post subject: Moddled Sound after recapping
PostPosted: Nov Fri 04, 2016 3:42 pm
I've worked on a Troy model unknown with push button tuning.
There is no model number but the chassis is similar to a model 57 revised so I've used that to work from.
I've replaced all of the caps and resisters except for the low value plastic pieces and tested all of the tubes. The radio plays well, has good volume and picks up a couple of weak station very well. The only issue is that the sound starts out clear and then after a short time becomes muddled. Then I turn off the set, count to ten , turn it back on and the sound is clear again. I have played it for many hours throughout the day with clear sound, but the next morning this routine starts over again. Any ideas??
 Post subject: Re: Moddled Sound after recapping
PostPosted: Nov Fri 04, 2016 7:40 pm
Have you seen this website?
http://www.geojohn.org/Radios/MyRadios/ ... Radio.html
He used a Model 57 schematic and redrew it to match his Model 75.
Did you discover a bias cell under the chassis? That component should definitely be checked.
Distortion could be tube related, or due to heat stress on some other part.
I am attaching some pics from that site of the schematic and the bias cell.
Funny we can't find that bias cell on his schematic?
OK, further scrolling down reveals he has added a voltage divider to eliminate the cell. He found that a negative bias of -2 volts works best. Had distortion problems before getting the bias right.
Burl Ives, RIP, oldtimer.
[:l>)
PostPosted: Nov Tue 29, 2016 4:19 am
It's Fixed.
The source of the muddled sound turned out to be one of the .0005 molded plastic caps.
PostPosted: Nov Wed 30, 2016 7:13 am
How did you find the trouble??
PostPosted: Dec Mon 12, 2016 6:43 pm
I got a little ahead of myself in thinking the .0005 caps were the source of the trouble, although they were in bad shape. I've been playing the radio 11 hours a day, all week and have had less events of muddled sound once I replaced the 6A7 and 41 tubes. But the muddled sound gremlin still pops up after the set has played for a few hours. Turn it off count to ten and turn back on and the sound clears up. I sound add that the muddle sound is more subtle now than in the past.
PostPosted: Jan Fri 13, 2017 7:12 pm
I replaced the 75 tube and that seems to have fixed the problem.
I've played the radio for a time now and the muddled sound seems to have cleared up.
Post New Topic Post Reply  [ 6 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: GSD, lorenz200w, sdradioman, Tom Albrecht and 10 guests
