It is currently Aug Sat 17, 2019 6:01 pm
 Post subject: ADC Electret Condenser Microphone Battery
PostPosted: Jan Sat 14, 2017 5:25 pm
I picked up an ADC Electret Condenser Microphone and need to identify the battery required. There are no markings, model number or documents I can find. I did find the pics below on epay, but the seller could find no numbers on the battery he's including in his auction.
Measuring the battery compartment and comparing to a AAA, the battery seems it would be a little wider than a AAA and about 2/3's or half the length. No idea on voltage.
Any thoughts?
 Post subject: Re: ADC Electret Condenser Microphone Battery
PostPosted: Jan Sat 14, 2017 6:20 pm
Looks like a mercury battery to me.
PostPosted: Jan Sat 14, 2017 11:05 pm
Thanks. Maybe an "N" battery? I'll keep researching!
PostPosted: Dec Thu 13, 2018 9:09 pm
12v A23, A23BPZ-2 Battery.... Yes 12 volts. The Alkaline version is prefered..
Also be aware when turning this mic on you will get a 12v pulse!!
This mic is has a fairly flat response and was used to calibrate speakers for ADC's graphic EQ equipment.
PostPosted: Dec Fri 14, 2018 2:28 am
If the mike has only two contacts you will need a load resistor.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Dec Fri 14, 2018 3:06 pm
I'd forgotten about this post. I did find a battery. The mic is unbalanced - or has a 1/4" phone jack as I received it. Interested in more detail on the load resistor mentioned.
PostPosted: Dec Sat 15, 2018 7:27 am
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
Users browsing this forum: Ken Doyle and 4 guests
