Author |
sdyer
Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration Posted: Jan Sat 14, 2017 12:23 am |
I used Minwax Furniture Refinisher on the top. The wood underneath was clean and free from scratches, so it should look great once it's all done. I'm going to replace the missing veneer on the edges, sand it lightly and stain it. Then, lacquer. I only did the top because it was warm - 50's - for only a little while the other day. It's January in MA. I'm not planning on really being able to finish the stripping and finishing and stuff until summer when it's warmer here. Attachment:
Top |
sdyer
Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration Posted: Feb Mon 20, 2017 5:15 am |
Top |
wrnewton
Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration Posted: Feb Sun 26, 2017 1:58 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6217 Location: Cleona, PA
I've been reading your electronic repair and now cabinet repair with interest: I love doing basket cases, and you are doing really great. Congratulations.
_________________ Reece
Top |
sdyer
Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration Posted: Mar Fri 03, 2017 5:35 am |
Top |
sdyer
Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration Posted: Apr Mon 10, 2017 12:25 am |
Another warm day, another chance for some outdoor woodworking. Today I got all of the areas where the new veneer needs to go, sanded. The big side and top were VERY warped - each board was basically concave. Many hours of sanding and filing later, I believe the exposed areas are ready for the new veneer.
Attachments: |
File comment: This thing is great, once you get the paper to stay in.
File comment: Clean, flat, ready for veneer.
Top |
sdyer
Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration Posted: Apr Mon 10, 2017 12:41 am |
Many props to Radio Daze. They created deals for the faceplate glass, and now offer it as a standard product - printed on glass and everything - at http://www.radiodaze.com/philco-model-48-1000-television-screen-glass-item-fp-ph-48-1000/. I'd shipped them the original glass from my TV, and they printed it on that for me. Awesome! Remember, too, that they updated their 48-1000 control decal set for me ( http://www.radiodaze.com/philco-48-1000-decal-set/) to include the hidden controls under the pull down panel. They've been great.
Attachments: |
File comment: Faceplate glass - before.
File comment: Faceplate glass - after cleaning and reprinting by Radio Daze.
Top |
Tommgb
Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration Posted: Apr Mon 10, 2017 2:33 am |
Joined: May Mon 30, 2011 10:12 pm Posts: 1513 Location: Glendale, CA
You're right, Radio Daze did a really nice job!
_________________ "A challenge to be met, rather than an obstacle to avoid." - Mr. Data
Top |
Radio Fixer
Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration Posted: Apr Mon 10, 2017 8:47 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3625 Location: Nr London, England, SS1 3PT
Really useful to have them. Folks over here use them as well, costs a bit more with the shipping. I have one radio with one of their dials in.
If I can do it with one screen cost is about the same so I normally create the artwork and drive up the road ... Every extra screen is another £40 so R.D. is the way to go then. Odd that there isn't a flat bed printing service over here.
Gary
Top |
Budward
Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration Posted: Apr Tue 11, 2017 1:36 am |
Joined: Mar Sun 19, 2017 11:52 pm Posts: 145 Location: Memphis, TN
I'm joining this party late. I'm on my first radio restore and have a cabinet that needs some gluing to get it structurally sound again. What kind of glue did you use?
_________________ GE J-64 first restore underway. GE J-105 awaits.
Top |
sdyer
Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration Posted: Apr Tue 11, 2017 2:36 pm |
Budward - mostly I used Titebond 3 wood glue. But I've also used elmers wood glue with no problem. I researched glue when I started and my impression is that unless there is a special need - heat, moisture, extra strength, or something like that - that any of the wood glues is pretty good. One thing that has been a GREAT help is the injector kit. With these syringe-like things I can get glue deep between boards and into other small or tight spots.
Attachments: |
Top |
Budward
Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration Posted: Apr Tue 11, 2017 3:31 pm |
Thanks. The injector kit looks like a handy item to have. Googling now.
Top |
sdyer
Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration Posted: Apr Tue 11, 2017 6:25 pm |
Top |
Budward
Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration Posted: Apr Wed 12, 2017 1:10 am |
Ordered. Thanks again.
Top |
sdyer
Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration Posted: Apr Fri 14, 2017 10:46 pm |
So, here is my plan for the refinishing, once I get the veneers on. I'll be practicing all of this on a test board of the new mahogany veneer. Not sure I'll do the "**" items.
--- sand - down to barest possible, good-surface wood **wood conditioner - do I need do to this before the stain? stain - not too much, but enough for a deep color Sanding sealer - to prevent the grain filler from staining the wood (i.e. preserving the just-stained color) grain filler - to fill in the grain divots sanding sealer - after grain filler to do final evening out initial clear lacquer - several coats, sand between - goal is very smooth surface to support the decals and the base’s black paint --- black paint - mask it off, paint the base and picture-frame insides black rub out black - maybe to soften the gloss black a little, use some steel wool on the black layer gold paint - paint inner edge of picture-frame --- decals - apply the decals to the nice now-smooth surface --- final clear lacquer - several coats, sand between **final semi-gloss coat - add a semi-gloss coat or two, over the gloss layers? rub out - to nice rich deep satiny finish paste wax - wax and buff done - finally ---
Attachments: |
File comment: This test board has the 1/16 maple and 1/32 mahogany veneers glued on. Testing all steps on this board, shown just before routing the edges to conform to the substrate.
Top |
sdyer
Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration Posted: Apr Fri 14, 2017 10:51 pm |
Some questions on staining the original wood. It appears that the sides of the cabinet are solid wood, or at least a solid sheet of veneer. The top is veneer definitely, similar to the new veneer I have - little strips of mahogany in a sheet. I sanded a little area of both with 100 - see below. I'm wondering whether there will be an issue with the wood taking the modern Minwax stain? (I'm going with red mahogany, most likely - we'll see how the test board comes out). Should I sand the original wood more? less? Any issue with the old stain or dye interfering with the new stain?
Attachments: |
Top |
sdyer
Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration Posted: Apr Mon 17, 2017 10:56 pm |
Top |
sdyer
Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration Posted: Apr Mon 17, 2017 11:02 pm |
There are traces of the original finish left. While sanding I came across a patch under the front controls. It matches up almost exactly with the test board I'm working on. I think I'm on the right track.
Attachments: |
Top |
Tommgb
Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration Posted: Apr Tue 18, 2017 2:31 am |
Looking pretty good! Compared with what this cabinet looked like when you started, you've come a long way.
Top |
sdyer
Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration Posted: Apr Wed 19, 2017 4:16 pm |
First application of black lacquer, to the fold-down control cover. I sprayed a few coats of minwax clear lacquer to seal the wood, gave it a light sanding, then several coats of the black. So far nice and smooth and clear. There will be a few more coats of minwax clear, then rubbing out to hopefully a nice lustery finish.
Attachments: |
Top |
sdyer
Post subject: Re: Philco 48-1000 Extreme Cabinet Restoration Posted: Apr Wed 19, 2017 5:23 pm |
This is my test board. I'm not sure what the substrate is - just some scrap I had around. On top of that is what I will be applying to the TV cabinet - 1/16 maple veneer, and over that 1/32 mahogany veneer. When I stained the test board, the mahogany came out great. The maple didn't absorb very much though. As this will layer will be visible along at least one seem on the TV, I need to darken it. I tried extra stain and a brown sharpie, but neither really did well. The maple is just very hard.
Any recommendations on how to darken the maple layer?
Attachments: |
Top |
