It is currently Mar Wed 20, 2019 6:36 pm
 Post subject: Crystal Earpiece
PostPosted: Dec Thu 15, 2016 11:59 pm
A very good "tool" to have on the bench is a crystal earpiece. It can be used to check where you lose a signal in the audio chain and does not load down the circuit. Just be sure to use a small value capacitor for isolation.
 Post subject: Re: Crystal Earpiece
PostPosted: Dec Fri 16, 2016 9:19 am
A better tool would be an amplifier; a Transistor radio, with leads connected to ground, and through a cap to the VC wiper, can serve as a cheap audio signal tracer.
PostPosted: Dec Fri 16, 2016 2:39 pm
I could also use a scope as a signal tracer, which I do have on my bench. The reason I posted this is because not everyone may have a spare tools or test equipment laying around, but the job could still be done with alternatives.
PostPosted: Dec Fri 16, 2016 3:58 pm
RCA and other manufacturers that published service handbooks for their receivers often recommended a battery and a pair of magnetic headphones. Depends what one is trying to measure as well as training the ear to a "defective" sound...
PostPosted: May Wed 17, 2017 6:47 am
Its a good idea i used the same idea for signal testing along the circuit chain ,i used it before i had a scope but hearing it is just as good in some ways .
PostPosted: May Thu 18, 2017 9:44 pm
A crystal earpiece makes a good, simple, cheap tracer.
Using the audio part of a transistor radio will also work but the input impedance is low and may load enough to make a good circuit appear weak or defective.
There are circuits on the web that precede an LM386 amp with a FET input stage. I built one years ago and it is a very handy little item.
RRM
PostPosted: May Sun 21, 2017 4:53 pm
Awhile back, I put one of those old radio shack 4transistor amplifiers in an old aluminum box with a small speaker and used a piece of shielded cable as a probe. Very useful.
PostPosted: May Sun 21, 2017 6:14 pm
There are very inexpensive LM386 amplifier boards and kits available on Ebay; some with free shipping.
http://www.ebay.com/itm/1pcs-LM386-Supe ... Sw14xWMfNq
If you need a pre-amp stage, they also have microphone amps that will serve.
http://www.ebay.com/itm/Multi-Stage-Ele ... SwYIxX92zc
My homebrew signal tracer is a 1458 op-amp followed by an LM386 audio amp. A couple of hundred mW is more than enough audio.
Post New Topic Post Reply  [ 8 posts ]  Moderator: Chuck Schwark
