It is currently Jan Fri 21, 2022 1:40 pm
 Post subject: Rebuilding the candohm resistor in a Philco 39-55
PostPosted: Sep Thu 14, 2017 4:12 pm
I was wondering if anyone has rebuilt the multi section candohm in a Philco 39-55. One section of mine is open and a couple of others are pretty far off their design resistance values. I was going to go through and add up all the tube current draws to calculate the wattage requirements for each section, but was sure someone here has done that already and could share the power ratings they came up with for each resistor.
Here is the schematic:
http://www.nostalgiaair.org/pagesbymode ... 013299.pdf
Hard to read, but the resistances from left to right are 111, 29, 15 and 14 ohms.
Thanks for any help!
Jaime
 Post subject: Re: Rebuilding the candohm resistor in a Philco 39-55
PostPosted: Sep Thu 14, 2017 5:29 pm
Hi Jaime,
I've replaced a number of Candohms over the years.
Zenith published a list of part numbers with individual section power ratings.
Most have one or two sections with ratings >1 watt while the rest are low-power.
The highest power in any multi-section Candohm is 6 watts.
Here's that Zenith list if you want to peruse it:
http://www.atwaterkent.info/Images/Zeni ... istors.pdf
You might find your part there, since Candohms were made by an independent company.
Unfortunately, I know of no such list for Philco radios.
The simple way to calculate dissipation is using voltages.
If a voltage drop E appears across a resistor R, the power is E * E / R.
I would use a replacement resistor with at least 3 times the calculated value.
- Leigh
73 de W3NLB
http://www.AtwaterKent.info
PostPosted: Sep Thu 14, 2017 6:32 pm
Error: see post below. ▲ from six-page Service Bulletin No.310 in DjVu format
available here→ https://tinyurl.com/tom-bavis courtesy of Tom Bavis.
I use this DjVu reader (safe download from sourceforge.net) works great.
http://antiqueradios.com/forums/viewtop ... 9#p2746819
If you are using a Windows computer, here is a direct link to the DjVu reader .exe file.
https://sourceforge.net/projects/djvu/f ... rror=netix
Save it to your desktop, open it and follow the installation instructions.
Somewhat more legible Rider's Philco page 9-55 + 9-56
http://americanradiohistory.com/hd2/IDX ... e-0070.pdf
Edit: Most all of those 'oddball' values are... http://antiqueradios.com/forums/viewtop ... 2#p2469692
Edit: image updated.
PostPosted: Sep Thu 14, 2017 7:54 pm
Jaime
Hi Jaime,
+1 to comments already offered by Leigh and Greg.
The only thing which concerns me is your statement above. Not unusual to find one or more sections of a candohm resistor which are either open or shorted. But they being wirewound resistors, it is somewhat unusual to find intact sections which are "pretty far off their design resistance values".
Poston
PostPosted: Sep Thu 14, 2017 10:27 pm
Error: Disregard the multi-section resistor image posted above.
It's for Philco 39-116 a 14-tube radio.
Bulletin 310A contains service data for model 39-55
111Ω 29Ω 15Ω 14Ω is correct.
Apologies for any confusion. Greg.
PostPosted: Sep Fri 15, 2017 9:28 am
This is a neat way of doing it using 10W metal clad WWs. Of course they don't all need to be this wattage but they are convenient as they come with lugs so effectively can be made up to take the old wiring.
I used a piece of ali metal L strip.
Gary
PostPosted: Sep Fri 15, 2017 3:33 pm
The solution which Gary posts above is a very good one. I too have started using these metal-clad WW resistors with lugs; I purchase mine from Mouser. An arrangement like Gary's photo is especially good where space is at a premium in a tightly-packed chassis, and where a conventional lug strip might interfere with surrounding components.
Poston
PostPosted: Sep Fri 15, 2017 10:21 pm
Gary posted a picture a while ago, but now seeing it in a chassis is something.
The way you arrange them makes it look very professional. Do you put any goo
(The gray stuff that goes between a proc and heat sink)on the resisters?
Freeman.
PostPosted: Sep Sat 16, 2017 8:48 am
Can do if you want but its unnecessary unless one is really high watts !!
Laid it out on a drwg package and printed it out, stuck the piece of paper on the metal strip and drilled the holes then soaked off the paper.
You can get lower wattage resistors but they are too fiddly for me to work with.
Gary
Post New Topic Post Reply  [ 9 posts ]  Moderators: Norm Leal, Marcc
Users browsing this forum: Dennis Wess, Google [Bot] and 24 guests
