It is currently Oct Wed 21, 2020 12:27 am
 Post subject: Deja Vu Options
PostPosted: Sep Mon 25, 2017 12:21 pm
Hello. Can anyone recommend a Deja Vu viewer for windows XP ? Most online now are only for Vista and up, not XP. Most of THOSE are also from sources I consider suspect ... don't want to get a virus over this ...
any assistance appreciated
 Post subject: Re: Deja Vu Options
PostPosted: Sep Mon 25, 2017 12:23 pm
BAMA has recommended options.
PostPosted: Sep Mon 25, 2017 12:36 pm
I am not sure which of the viewers have current versions that support XP so that may be an issue requiring you to find an older version rather than the ones linked via the edebris site.
I started using IrFanview most of the time; I downloaded it primarily for resizing jpg files but I found that it handles DjVu files quite well.
Most freeware programs are going to be hosted on sites that do try to stick other content with them so un-check any options that add stuff and then run Malwarebytes or similar after download.
Rodger WQ9E
PostPosted: Sep Mon 25, 2017 12:48 pm
To open and view .djvu files (pronounced déjà vu).
I use Léon Bottou's Djview, available from djvulibre.djvuzone.org. Works great.
Download from sourceforge https://sourceforge.net/projects/djvu/files/
Edit: image updated.
PostPosted: Sep Mon 25, 2017 1:29 pm
Thanks to all!! I got the french one to work :) ... Thank you Egg, and the rest of you for your assistance.
I found I had to download the djvu file, then open deja vu, and then use IT to open the file I'd downloaded. Simply clicking on the BAMA djvu file came up with various errors. Oh well, I'll keep fiddling with it. "handle not found" is a new one on me :)
anyway, thanks again
Barry
PostPosted: Sep Mon 25, 2017 1:48 pm
To associate a file with a program in XP
https://microsoft.com/resources/documen ... ogram.mspx
Edit: DjVu format examples can be found here
http://techpreservation.com/schematics/
and here http://www.Aduiophile.com/Philco.html
PostPosted: Sep Mon 25, 2017 2:06 pm
I'm sure if Greg suggested it... it's probably a great program but if you have the time you might want to try this program as well.....I've been using WinDjView on my old XP for years...I also have it installed on a couple of Win 10 machines and never had a problem opening DjVu files
https://windjview.sourceforge.io/
Ken
PostPosted: Sep Mon 25, 2017 4:14 pm
A suggestion...
If you have a print option in the DjVu reader, print the document to a PDF file.
That way you can access it from a multitude of viewers.
Post New Topic Post Reply  [ 8 posts ]  Moderator: Alan Voorhees
Users browsing this forum: arbilab, beat_truck, Blustar1, BobWeaver, Dale Saukerson, Richard Jensen and 24 guests
