It is currently Jun Thu 27, 2019 8:03 am
 Post subject: Scott LK-60B Amplifier Problem
PostPosted: Mar Fri 02, 2018 1:34 am
I am not versed in electronic circuitry except for being able to solder and use a digital multimeter in checking voltage and resistance, etc. I recently decided to check the operation of the LK-60B Scott Amplifier kit I built in the late 1960s. It has been in storage since I purchased a surround sound system some 20 years ago.
In using Section 4 of the manual to check the balance and bias without instruments, I found that the left channel bias read 10 on the meter but the balance was OK. I thought that perhaps the electrolytic capacitors were at fault since many years had elapsed since it was constructed. I started checking the capacitors on the left amplifier driver board by measuring the AC voltage across them. I found that the voltage was low across all of them except for C6 which measured 25 VAC.
Since the right channel bias and balance was OK I decided to check the voltage across the C6 cap on the right channel board for comparison but in the process the probe slipped and I believe I either grounded the collector of Q4 or I shorted the collector of Q4 to the emitter of Q3. At any rate the 1-1/4 amp slo-blo fuze blew. When I replaced the fuse and turned the unit on, R18 got hot and started to smoke.
I feel very foolish having screwed up, especially since I don't know where to start in the repair process. Hopefully I didn't do a lot of damage.
Can anyone help with this? I scanned a copy of the schematic and the driver board layout from the manual. I also took resistance measurements which are penciled in on the board layout if that helps.
schematic.pdf [173.73 KiB]
Downloaded 65 times
rt chan driver bd.pdf [217.75 KiB]
Downloaded 46 times
 Post subject: Re: Scott LK-60B Amplifier Problem
PostPosted: Mar Sun 04, 2018 3:15 am
Most likely you shorted a driver transistor which may have carried over and taken out an output. There are two ways to approach this problem. easiest is to reduce supply voltage and bring it up slowly, comparing the voltages between the left and right channels. Often you can see a trend where the voltage on one side or the other of the bootstrap is pulling toward one side or the other. this is indicative of a transistor conducting too much, often because of a short on that side. You then replace the transistor and repeat the process.
You say you have limited test equipment so I assume you may not have the variac or limiting supply needed to do this. An alternative requires pulling outputs and drivers on the bad channel and checking them out of circuit for shorts. This should be done on a high resistance scale of your meter. Also be on the lookout for any where leakage in the reverse direction is found. Those, as well as any that read open in both directions, should be changed out. While they are out of circuit, also check all diodes in the driver circuit for open / shorts. Don't forget to also check D1 -D2 which may be mounted on the heatsink.
Next reapply power (a variac would be helpful here, as you could do as stated in the first paragraph, otherwise you are taking a chance!). One trick I have used is to use a smaller fuse which will be less forgiving of problems. (.75 or 1 A for this one) Solid state amplifiers like this do not use full supply current until the volume is turned loud, so voltages should come up good as long as you keep the volume low. If the voltages do look good, then you can put the specified fuse in and treat it as normal.
To go into more will require I have some actual voltages and conditions to make a more indepth evaluation.
PostPosted: Mar Mon 05, 2018 12:00 am
Thanks for the reply CaveRat. Yes, you are correct in assuming that I don't have a way to reduce the supply voltage. I'm guessing the best I can do is the alternative you mention in your second paragraph. I'm not sure what you mean by "pulling outputs and drivers" although I can isolate the right channel driver board by unsoldering 8 wires (not including ground) which connect it to the rest of the circuitry. What do I need to do to "pull outputs"? D101 is on the driver board but I'll have to look for D102. As you say, it must be on the chassis somewhere.
PostPosted: Mar Tue 06, 2018 3:45 pm
By "pulling" I mean you will need to physically remove the transistors from the circuit to take the resistance measurements. If you don't you will get false readings through other components. Silicon transistors should read about half scale on a conventional VOM in one direction, and when the leads are reversed they will read open. Check from base to emitter and base to collector to obtain these readings. The emitter to collector reading should be open both ways in most cases. This will isolate a shorted transistor as well as one which is open. It does not address gain issues, but in your case it looks like a case of short / open. (Usually what happens when a "mistake" is made!)
Diodes should read half scale in one direction and open in the other.
Note too these readings must be made with a conventional analog Volt /Ohm meter, not a digital one since the voltage supplied by digital meters often do not allow the barrier voltage of the transistor junction to be overcome. (they read open in both directions even on a good transistor)
PostPosted: Mar Tue 06, 2018 8:01 pm
I do have an old Simpson 260-2 VOM I can use instead of my digital meter as you suggest. I'm hoping that Q110 and Q111 are not damaged because they are a "matched pair" (whatever that means) and I don't know how I would be able to purchase another "matched pair" to replace them.
OK, I'll dig out the old Simpson and see what I can find. Fortunately Q1, Q3, and Q4 plug into sockets on the board and are easily removable for checking. They also have winged heatsinks on them which is what my probe touched to cause the problem in the first place. It looks like I will be able to pull Q110 and Q111 from the circuit by unsoldering wires from their leads to terminal strips. I'll let you know when I get the results. Thanks again for your help.
PostPosted: Mar Mon 12, 2018 9:34 pm
Hey CaveRat, I was incorrect in my last post. Q1 is not plugged into a socket, it is soldered into the board.
At any rate, I isolated what I could by unsoldering and cutting connecting wires and here is what I found:
Q3 and Q4 are definitely bad - shorted in all measurements
D101 and D102 are OK
Q110 and Q111 are OK
D201 and D202 are OK
As for Q1, Q2, D1, C6, and R18, I don't know since they are soldered into the board. The results I got for Q1, Q2, and D1 are not good but, as you say, I may be seeing false readings through other components. What do you suggest? Should I replace Q3 and Q4 and see what happens when I apply power?
PostPosted: Mar Tue 13, 2018 5:04 pm
This type of failure is unusual; most times outputs take out the drivers but since the accident originated in the driver stage I would assume that high current may have extended further upstream. Thus I would have reservations regarding the condition of Q2 in particular.. If you simply replace Q3 and Q4 alone it is possible Q2 and Q1 are also bad. Powering up under those conditions could easily take out your replacement transistors again and also the outputs.
I would recommend at least pulling Q1 and Q2 and verify they are good before powering up. If they are good there is still a possibility of taking out your replacements if something else is bad, but that possibility would be reduced if you know for certain Q1 and Q2 are good. You have already established the outputs are good according to your previous post so that removes the most common cause of driver failures.
Makes it hard without a variac, but when I get these type of failures a trick I use is to remove the outputs and power up using the variac to reduce supply voltage. As I raise the voltage I monitor the bootstrap voltage. It should remain about half of supply voltage as you increase the line volts. If something is amiss, the voltage will swing either too high or low and you need to find out why. Once you reach full supply voltage and if everything else looks good, then measure the difference (emitter - base) voltage going to the output transistor sockets. It should be under 1 volt on each transistor. if so, power down and reinstall the outputs and test again. Check bias current and adjust according to manufacturer specs. That should have it working.
PostPosted: Mar Tue 13, 2018 6:16 pm
While I don't have a variac to use I have taken the liberty of ordering extra parts such as Q1 and Q2 replacements including the sockets which I can solder on the board to avoid having to solder the Q1 and Q2 leads - this always makes me nervous. I've also purchased an extra D1 and R18 just in case. Do you think I can get away with replacing Q!, Q2, Q3, and Q4 or should I also replace D1 and/or R18. Could these last two cause a major problem if they are bad and I don't replace them?
PostPosted: Mar Wed 14, 2018 1:41 pm
If the digital meter has a diode test function you can use that for most transistors.
PostPosted: Mar Wed 14, 2018 10:37 pm
If you have them available I would change Q1 and Q2 just as a precaution since it is unknown what stress they may have experienced. As for the diode and resistor if they do not appear overheated you may be OK. Just check all voltages around the drivers, watch for potential high current on the outputs, and be aware if something isn't quite right these are possible causes. (The resistor moreso than the diode)
PostPosted: Mar Thu 15, 2018 2:42 pm
Great, thanks for the advice. I'll replace Q1 and Q2 as you suggest using sockets and get back to you with the results after I fire it up - probably over the weekend.
PostPosted: Jul Sun 01, 2018 8:43 pm
Hey CaveRat,
Sorry it took forever to get back to you. The project got sidetracked until a few days ago. The good news is, thanks to your help, the right channel is fixed.
Now I need to work on the original left channel problem which is in the 4.3.a balance and bias checks using the meter function switch. The right channel checks as it should with the balance being 3.5 on the meter and the bias being 0. The left channel balance is OK at 4.5 but the bias is 10 on the meter. I've checked left channel driver board voltages and they all seem to be OK except at the base of Q4/collector of Q2 which measures 0 instead of 1.2 volts. Do you think C8 could be shorted to ground?
PostPosted: Jul Tue 03, 2018 2:33 pm
Possible but I doubt it. More likely is that Q2 is cut off (no collector current) Measure the emitter and base voltages on Q2 and Q4. You should see a difference of about .6 volts between the emitter and base in each case. If it's less then the transistor is cutoff. Te cause is a matter of following back through to find why the preceding stage is not pulling sufficient current to cause the next to conduct.
Be aware too that an emitter - base short in either transistor can have a similar effect. In either case the voltage between E - B will be where to begin.
PostPosted: Jul Tue 03, 2018 7:55 pm
Thanks, CaveRat. I'll check it out. Fortunately, when I purchased transistors to fix the right channel I bought extras. I'll let you know what I find.
PostPosted: Jul Tue 03, 2018 9:46 pm
As you advised I compared emitter and base voltages for Q2 and Q4 and as a check I also recorded the voltages for the right channel which seems to be working. Since the voltage difference I was looking for was so small (0.6 V) I used a digital meter.
Left channel:
Q2 emitter = 38.5 V, base = 38.7 V
Q4 emitter = 0.7 V, base = 0 V
Right channel:
Q2 emitter = 37.3 V, base = 37.1 V
Q4 emitter = 0.05 V, base = 0.6 V
Just for the heck of it I replaced Q4, which has a socket, and I got basically the same voltages as before. Do you think I should un-solder and replace Q2?
PostPosted: Jul Wed 04, 2018 7:59 pm
Q4 is not correct. As it reads with .7V on the Emitter and 0 Volts on the Base the transistor should be cut off. This would also cut off Q11 Under those conditions, unless something is causing Q11 to conduct (It shouldn't) the voltage on the emitter of Q4 should be near 0. Sounds like leakage through a transistor causing that .7 V to be on the emitter.
You might try replacing Q2 since you have the parts. However since both channels are working with only .2 volts difference between E and B That may not be the problem. My concern is why you have .7 on the Q4 emitter when the base is 0 and that transistor is cut off. (0V on the base) Q11 leakage? Somewhere there is current flowing that gives the .7 V across R19, and with Q4 cut off there should be none through its emitter. Yet apparently there is.
PostPosted: Jul Fri 06, 2018 5:59 pm
I'll be out of town for a week and a half so I'll try replacing Q2 as you suggest when I return. I'll get back to you with the results.
PostPosted: Jul Sun 22, 2018 5:40 pm
Hey CaveRat,
I'm back in town. I replaced Q2 with the same results as before. The left channel bias is still a problem. I even temporarily switched the Q2, Q3, and Q4 transistors from the working right channel to see if it would make a difference but no change. Could Q1 be the problem? Yikes it's frustrating. Any new thoughts on a fix?
PostPosted: Aug Fri 03, 2018 5:32 pm
Sorry for the delay; I have been out of town as well (2 weeks in Peru)
There is a way to pin this down, but without a variac to lower the supply voltage I hesitate to do this as it could cause problems if full voltage was suddenly applied. What I do is to pull both output transistors then slowly raise the supply voltage while measuring the bias on each driver transistor What yo are looking for is an imbalance in the bias applied to the E-B of the outputs. It should remain the same on both sides of the bootstrap, and the bootdtrap should be half of the supply voltage. But as you raise the supply you must be ready to cease increasing it if at any time the bootstrap is not at the half voltage potential. This would be indicative of imbalance and is the source of your problem.
Also have you verified C4 and C5 as not shorted? Just a couple things that can be checked...
PostPosted: Aug Mon 06, 2018 8:11 pm
Hi CaveRat,
Peru huh? How cool! Glad to have you back.
I'll try checking the caps you suggest for shorts. The variac subject sounds like it may be beyond my capabilities but I did see some on ebay for around $50. I suppose I could resell it on ebay after I use it and maybe get most of my money back.
