Page 1 of 1
[ 2 posts ] |
Author |
SparkyDan
Post subject: Toner, Dye or Stain? Posted: Apr Tue 24, 2018 10:17 pm |
Member |
Joined: Apr Sun 23, 2017 11:22 pm Posts: 1062 Location: 44035 (Near Cleveland Ohio)
I'm looking for some advice on how to proceed with this. I've had a couple radio cabinets with similar issues, and wasn't happy with my results. I've stripped this mahogany rocking chair (my wife's grandmother's grandmother's), and as you can see there's a lot of difference in the wood color. There seems to be a lot of red/orange pigment coming off; I used solvent stripper, and have washed it several times with acetone/lacquer thinner solution. I really don't want to sand it, and have no idea how deep the coloring goes. I'm looking to color it to a dark walnut shade (or thereabouts). Any product advise would sure be appreciated. (P.S.: I know it's a cardinal sin to refinish antique furniture, but this chair had a couple sloppy coats of varnish slapped onto it over the years, so I didn't feel too bad doing so.)
Dan
Attachments: |
Top |
Scott
Post subject: Re: Toner, Dye or Stain? Posted: Apr Thu 26, 2018 12:06 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6362 Location: Montvale NJ, 07645
I would use an oil based stain on that because a dye dries too fast and there are a lot of in's and out's there. I would then use a second (or third) coat on just the light wood areas as needed. If that didn't do the trick, I would use a matching toner to get the light areas to match, but only if using a compatible top coat such as lacquer. Pretty sure that Mohawk makes their toners to match their stain colors.
If it were my chair, personally, I would use a catalyzed lacquer or conversion varnish for durability.
Top |
Page 1 of 1
[ 2 posts ] |
Moderator: Peter |
Who is online |
Users browsing this forum: No registered users and 8 guests |
