It is currently Dec Sat 04, 2021 9:42 am
 Post subject: Testing UX-120 Tube on Tube Tester
PostPosted: May Fri 25, 2018 2:34 am
I would like to test some UX-120 tubes on my Hickok 600a . The voltage would be the same as 99 tubes, but I haven't found any test data for them. Does anyone have that or know where to find it?
Dan
Museum Curator
 Post subject: Re: Testing UX-120 Tube on Tube Tester
PostPosted: May Fri 25, 2018 2:59 am
Does it list a 20?
PostPosted: May Fri 25, 2018 3:40 am
No "20" listed.
Dan
Museum Curator
PostPosted: May Fri 25, 2018 3:44 am
Here's what I was able to find.
120 3.0 JR-3200-0 71 73 P4 525 OK above 325
PostPosted: May Fri 25, 2018 3:50 am
Thanks guys, I appreciate you taking the time to help me out.
Dan
Museum Curator
PostPosted: May Fri 25, 2018 3:05 pm
Lucky my Hickok came with the addendum books besides the roll chart. Otherwise alot of these prewar tubes would be a problem.
PostPosted: May Fri 25, 2018 5:46 pm
If we can look up "20" on the charts and have it apply to the -120 tube, is it also true that to test a -199, we can use the "99" settings?
Thanks.
PostPosted: May Fri 25, 2018 7:05 pm
Thanks.
Yep, on a 299 too...
FWIW, in a pinch a '99 can be used as a sub with reduced output power... B+ and bias changed to suit...
Chas
PostPosted: May Fri 25, 2018 8:38 pm
Ok, thanks - just tried it on the small pile of 199s I have, using the settings for 99 given by the documentation for my tester. It says to use only 65v on the plate, but isn't the 99 a 90v tube? I ask because some of them show not-so-good at 65 but very good at 90.
My tester is the Heathkit TC-2, which I know is pretty pedestrian...but it's rebuilt and accurate within its design limitations, and all I have right now.
PostPosted: Sep Tue 21, 2021 4:33 am
I have NRI-69 tube tester and the manual for NRI-69 instructs to use load 65 for X-99 and its variants. Does it mean 65V plate voltage?
The data below, says that the plate voltage for UX-199 is 22-45V. If that's true, load 65 should not mean 65 volts.
