Page 1 of 1
[ 10 posts ] |
Author |
atwaterkent1
Post subject: Testing UX-120 Tube on Tube Tester Posted: May Fri 25, 2018 2:34 am |
Member |
Joined: Sep Mon 18, 2017 2:23 am Posts: 8909 Location: Plymouth, MI
I would like to test some UX-120 tubes on my Hickok 600a . The voltage would be the same as 99 tubes, but I haven't found any test data for them. Does anyone have that or know where to find it?
_________________ Dan
Museum Curator https://roaringtwentiesantiqueradiomuseum.com/
Top |
azenithnut
Post subject: Re: Testing UX-120 Tube on Tube Tester Posted: May Fri 25, 2018 2:59 am |
Member |
Joined: Jan Mon 18, 2010 2:13 am Posts: 23219 Location: Dayton Ohio
Does it list a 20?
_________________ Radio Interests -Zenith -Sparton -Pre-War FM Consoles and floor models, the bigger, the better!
Top |
atwaterkent1
Post subject: Re: Testing UX-120 Tube on Tube Tester Posted: May Fri 25, 2018 3:40 am |
Member |
Top |
Bugman
Post subject: Re: Testing UX-120 Tube on Tube Tester Posted: May Fri 25, 2018 3:44 am |
Joined: Mar Sat 14, 2009 5:56 pm Posts: 4768 Location: VA 22602
Here's what I was able to find.
120 3.0 JR-3200-0 71 73 P4 525 OK above 325
_________________ I'm not a hoarder, I'm a caretaker of scarce commodities
Top |
atwaterkent1
Post subject: Re: Testing UX-120 Tube on Tube Tester Posted: May Fri 25, 2018 3:50 am |
Member |
Top |
wazz
Post subject: Re: Testing UX-120 Tube on Tube Tester Posted: May Fri 25, 2018 3:05 pm |
Member |
Joined: Jun Wed 08, 2011 2:33 am Posts: 12976 Location: Ohio 45177
Lucky my Hickok came with the addendum books besides the roll chart. Otherwise alot of these prewar tubes would be a problem.
_________________ Reddy Kilowatt says; You smell smoke? Sorry about that!
Top |
busterdog57
Post subject: Re: Testing UX-120 Tube on Tube Tester Posted: May Fri 25, 2018 5:46 pm |
Joined: Jul Sun 12, 2015 9:47 pm Posts: 208 Location: 94502
If we can look up "20" on the charts and have it apply to the -120 tube, is it also true that to test a -199, we can use the "99" settings?
Thanks.
Top |
Post subject: Re: Testing UX-120 Tube on Tube Tester Posted: May Fri 25, 2018 7:05 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 17712 Location: S. Dartmouth MA 02748-1225 USA
busterdog57 wrote: If we can look up "20" on the charts and have it apply to the -120 tube, is it also true that to test a -199, we can use the "99" settings?
Thanks. Yep, on a 299 too... FWIW, in a pinch a '99 can be used as a sub with reduced output power... B+ and bias changed to suit... Chas
_________________ List' & I will Enchant Thine Ear
Top |
busterdog57
Post subject: Re: Testing UX-120 Tube on Tube Tester Posted: May Fri 25, 2018 8:38 pm |
Ok, thanks - just tried it on the small pile of 199s I have, using the settings for 99 given by the documentation for my tester. It says to use only 65v on the plate, but isn't the 99 a 90v tube? I ask because some of them show not-so-good at 65 but very good at 90.
My tester is the Heathkit TC-2, which I know is pretty pedestrian...but it's rebuilt and accurate within its design limitations, and all I have right now.
Top |
ymg200
Post subject: Re: Testing UX-120 Tube on Tube Tester Posted: Sep Tue 21, 2021 4:33 am |
busterdog57 wrote: Ok, thanks - just tried it on the small pile of 199s I have, using the settings for 99 given by the documentation for my tester. It says to use only 65v on the plate, but isn't the 99 a 90v tube? I ask because some of them show not-so-good at 65 but very good at 90.
I have NRI-69 tube tester and the manual for NRI-69 instructs to use load 65 for X-99 and its variants. Does it mean 65V plate voltage? The data below, says that the plate voltage for UX-199 is 22-45V. If that's true, load 65 should not mean 65 volts.
Attachments: |
Top |
Page 1 of 1
[ 10 posts ] |
Who is online |
Users browsing this forum: davep44 and 8 guests |
