It is currently Mar Thu 21, 2019 8:36 am
 Post subject: WTB: 5 inch PM speaker - FOUND
PostPosted: Jul Mon 09, 2018 4:33 pm
Am seeking speaker only for Trav-Ler 5002 unit, my cone is GONE, appears to be 4 ohm. Output transformer not required.
I have zero idea if any of these are floating around out there!
Cone is 1 inch deep, from top of voice coil to outer edge of rim (see photo).
(Found an inexact but workable replacement, thanks to all responders, much good information.)
Last edited by depletionzone on Jul Thu 12, 2018 4:50 am, edited 2 times in total.
 Post subject: Re: WTB: 5 inch PM speaker
PostPosted: Jul Mon 09, 2018 6:12 pm
John,
I have used this product, and it worked well.
You have to dis-assemble the plastic frame, but
it wasn't that hard. There are some retainer clips
that release the frame.
Hotwax
Edit: Looking at your 5002 chassis, I'm not sure how
much depth you have to work with. This speaker may
be have too deep a magnet size.
https://www.allelectronics.com/item/sk- ... ill/1.html
PostPosted: Jul Tue 10, 2018 11:13 pm
If the voice coil is still working, you might consider reconing it yourself ...there's an older thread addressing that.
PostPosted: Jul Wed 11, 2018 3:51 pm
+1. matching these "chassis mounted" speakers is near impossible. The brackets vary all over the place so the protrusion and height vary. You can make a cone for this with manilla business envelope. Use regular paper to make a form first, fit it then cut two overlapping halfs that will nest under the existing voice coil flange. Its tricky but I have done it. Use any medium flexible material for the surround... faux chamois cloth I have used on larger speakers.
Search ARF for a post I did years back.... keywords are Mark Pictures I think.
Mark Oppat
Post New Topic Post Reply  [ 4 posts ]  Moderator: Philco Fan
