It is currently May Tue 26, 2020 9:37 pm
 Post subject: FOUND--PLEASE CLOSE Philco 37-61 chassis
PostPosted: Nov Thu 08, 2018 1:01 am
I need a Philco 37-61 chassis. Must be complete and serviceable--eg good PT, coils, etc.---I will get a repro dial if needed. This is for a radiobar, and I would like to confirm some measurements before closing the deal.
 Post subject: Re: WTB: Philco 37-61 chassis
PostPosted: Nov Thu 08, 2018 6:02 am
Do you want a chassis where the work is all but done or a raw chassis to do the work yourself? Earlier this year I bought a 37-61 chassis only for parts but found it had possibilities and I just couldn't tear into it. Just tonight I all but finished a restoration on it including cleaning and painting the chassis and installing new rubber parts on the tuner assembly. It still needs an AC power cord installed, the dial light innards replaced, a repro tuning dial and an alignment but seems to work fine on AM/SW. I was going to look for just a cathedral cabinet for it but I'd be happy to know this one went into a Radiobar.
PM me and I can explain a few other details about it and send you some pics.
P.S. - After I wrote this reply I happened upon your thread about the Radiobar. Ron Ramirez had said that the 37-61 was the correct chassis but you were wondering about the bottom center shaft being higher than the other two as they all look at the same level. I measured my chassis and the center (band switch) shaft is in fact about 3mm higher than the other two shafts.
PostPosted: Nov Thu 08, 2018 11:58 am
I'll consider anything....sending you a PM
PostPosted: Nov Wed 21, 2018 4:13 pm
Pix,
Where are you on this project? Do I need to go look in the shed to see if what I have?
Henry
PostPosted: Nov Wed 21, 2018 4:16 pm
I think something is lined up, but I don't have details yet.....still considering all options.
Even if I get a chassis, I may still be needing a speaker and knobs.
PostPosted: Nov Thu 22, 2018 1:08 am
Ok. Well I will try to get to it before the weekend is over. I have a couple of Philco cathedrals out there .Will let you know.
Henry
PostPosted: Nov Wed 28, 2018 10:00 pm
I finally got to it today.The radio worked when it went out to the shed but now it seems there is a broken tube with the octal key broken in the socket so I will need to get that out and test it out if you are still interested.
Henry
PostPosted: Dec Sun 09, 2018 3:32 pm
chassis and speaker are found (Thank You--radiohenry)---I'll contact the folks that offered knobs---this can be closed
Post New Topic Post Reply  [ 8 posts ]  Moderator: Philco Fan
Users browsing this forum: shutterdialradio, unuGHIDORAH and 6 guests
