Author |
sergneri
Post subject: What a difference 125,412 can make Posted: Nov Mon 05, 2018 3:43 am |
Member |
Joined: May Fri 25, 2018 1:50 am Posts: 793 Location: Petaluma, California
I acquired another $20 ZTO G500 this weekend. This one is the lower unit in the photo, with the green selenium rectifier, the number stamped into the metal on the chassis back is 186502. The top unit with the orange rec is another G500 I bought this spring and has 061090 stamped in the metal on the chassis back. Were there 125,412 units built between these two? (That seems like quite a lot!) After studying the new one for one evening, seems the layout in the top one is messy compared to the lower one and the components are different, the black resistors in the bottom unit and brown capacitors for example. Wiring layout seems to be very close. Colors on the wire fabric and general condition seems much better on the lower unit. Was the top one was built by someone having a bad day? The soldering style is very different between the two as well, the bottom one seems to have used much less solder and component placement is neater, more orthogonal, you could actually get a probe on the pins of the 3V4 without pushing too much. Thinking of the difference between FOXCON made electronics today and the Zenith manufacturing process then is, well, daunting. A search of the forum didn't give up a ZTO G500 serial number series, so I'm not sure if the number I'm referencing is the correct one, see red box in bottom picture.
_________________ Save the Knobs!
Top |
35Z5
Post subject: Re: What a difference 125,412 can make Posted: Nov Mon 05, 2018 1:32 pm |
Member |
sergneri wrote: Was the top one was built by someone having a bad day? Both radios were built on a assembly line, numerous persons had a hand in assembly. With less experience on the model, no doubt workers were not as neat in early production units(look about same to me). Code dates on components will give a approximation of period radios were built. I believe for TO that info has been well researched.
_________________ Tom
Top |
westcoastjohn
Post subject: Re: What a difference 125,412 can make Posted: Nov Mon 05, 2018 4:50 pm |
Member |
Joined: Dec Sat 24, 2011 9:17 pm Posts: 7189 Location: Vancouver Island, Canada
The biggest difference I see is the 1 or 2 watt 820K resistors on the socket next to the rectifier, 3V4 ?, were replaced with smaller 1M resistors. Yes, that makes more room at the socket. Anyway, it is interesting to compare.
_________________ Watch the doughnut, not the hole. Burl Ives, RIP, oldtimer. [:l>)
Top |
egg
Post subject: Re: What a difference 125,412 can make Posted: Nov Mon 05, 2018 6:59 pm |
Member |
Joined: Jan Tue 31, 2012 1:55 am Posts: 15350 Location: Mountains of Mourne. Ireland.
Zenith will have stamped the speakers with a date code. 343 equals Zenith... viewtopic.php?p=751406#p751406Example: 343818 343 - Zenith 8 - 1948 18 -18th week Greg.
Top |
35Z5
Post subject: Re: What a difference 125,412 can make Posted: Nov Mon 05, 2018 8:29 pm |
Member |
Did a little sleuthing, this link states around 90,000 G500 were built. I thought there was unlimitless info on these but I didn't find much either. http://www.radio-antiks.com/IndexRadio- ... h_G500.htmI will take a stab that 061090 is the 61,090 built, year 1950 & 186502 was 86,502 built, year 1951. That'd place builds 25,412 apart If the one with higher ser number was built in 1951, I'd bet my guesstimation is correct.
Top |
sergneri
Post subject: Re: What a difference 125,412 can make Posted: Nov Tue 06, 2018 12:12 am |
Member |
35Z5 wrote: Did a little sleuthing, this link states around 90,000 G500 were built. I thought there was unlimitless info on these but I didn't find much either. http://www.radio-antiks.com/IndexRadio- ... h_G500.htmI will take a stab that 061090 is the 61,090 built, year 1950 & 186502 was 86,502 built, year 1951. That'd place builds 25,412 apart If the one with higher ser number was built in 1951, I'd bet my guesstimation is correct. Well that makes much more sense, with the 0/1 year indicator. Love to know if a 49 series started with a 9. That makes me and the 186 born in the same year. My sleuthing showed some hits for H500 and H600 serial numbers, but not so much for G500. 90K units is still a lot of radios, but alas, not "unlimitless".
Top |
35Z5
Post subject: Re: What a difference 125,412 can make Posted: Nov Tue 06, 2018 1:16 am |
Member |
The one featured in link I posted has ser of 074983, speaker and electrolytic cap both have mid '50 code dates.
Top |
Martin Blankinship
Post subject: Re: What a difference 125,412 can make Posted: Nov Tue 06, 2018 6:48 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 777 Location: Kansas City
sergneri, I, with the help of respondents and photos I have found on the internet, have compiled serial production data on the G500 (plus hundreds of other Zenith models, 1923-1960). I plan to post a summary of this compilation on the G500 this evening.
_________________ Martin ***SERIAL NUMBERS: ZENITH & INTEROCEAN models 200-699 needed for project--PM me-THANKS***
Top |
sergneri
Post subject: Re: What a difference 125,412 can make Posted: Nov Wed 07, 2018 2:32 am |
Member |
Martin Blankinship wrote: sergneri, I, with the help of respondents and photos I have found on the internet, have compiled serial production data on the G500 (plus hundreds of other Zenith models, 1923-1960). I plan to post a summary of this compilation on the G500 this evening. Let me know if either of my G500's can help - I can hear them volunteering from here.
Top |
Martin Blankinship
Post subject: Re: What a difference 125,412 can make Posted: Nov Wed 07, 2018 4:26 am |
Member |
sergneri, I will need to check my data before posting--maybe tomorrow evening. I have serial information on 199 units.
It looks like you posted photos on one of your radios. If you can find the RETMA codes on the tuning condensers, which usually has an R/C (Radio Condenser Co.) 273 (mfr code) followed by six digits. The first three of those six would be the year and week. Example 273-008-108 would be a Radio Condenser Co. tuner manufactured in the eighth week of 1950. I don't know what the last three digits denote.
Top |
sergneri
Post subject: Re: What a difference 125,412 can make Posted: Nov Wed 07, 2018 4:54 am |
Member |
Martin, Unit 061090 is 004 (January 1950) Unit 186502 is 037 (September 1950) Edit: Last three digits on both is 108. Cheers, John
Top |
Hcompton79
Post subject: Re: What a difference 125,412 can make Posted: Nov Wed 07, 2018 6:52 am |
Member |
Joined: Sep Sat 27, 2014 4:24 am Posts: 1878 Location: Oxford, MI
In the hopes of contributing to the investigation here, I pulled down by G500 and recorded the serial number and a number of production codes.
Serial #: J-198363 Speaker Date Code: 343939 (Sept.-Oct. 1949) Tuning Capacitor Date Code: 273-937-108 (Sept. 1949) Electrolytic Can Date Code: 102948 (Nov.-Dec. 1949)
I also took a look at my copy of Bryant & Cones The Zenith Trans-Oceanic: The Royalty of Radios. They list that total production for the G500 was 89,681 units with 16,244 being produced in 1949, 51,634 being produced in 1950 and 21,803 being produced in 1951. They also say that the G500 was last offered in print advertising in May of 1951.
With the data listed in this thread we can summarize the following:
Unit J-198363 would have had to have been made after Dec. 1949 Unit 061090 would have had to have been made after Jan. 1950 Unit 074983 would have had to have been made after June 1950 Unit 186502 would have had to have been made after Sep. 1950
It would not appear that the serial numbers follow a congruent pattern as the OP points out there are 125,412 proposed units between his examples and with less than 90,000 examples produced (and only 51,634 in 1950) there can not be examples bearing every serial number.
I hate to correct 35Z5, but with only 67,878 examples produced in total by the end of 1950, that eliminates the possibility of the first digit representing the year as Unit 074983 could not have been the 74,983 example produced in 1950. Unless of course there were non-continuous serial number blocks being used.
My example also throws a wrench into the mix, as it has a J-Prefix, as do a number of other examples I have seen, which have the serial number printed on a paper tag affixed to the chassis rather than being stamped on.
I too would be interested in hearing the findings of Mr. Blankinship and whether he has a solution to decoding the G500 serial numbers.
_________________ Hunter
Top |
35Z5
Post subject: Re: What a difference 125,412 can make Posted: Nov Wed 07, 2018 4:32 pm |
Member |
Hcompton79 wrote: I hate to correct 35Z5, but with only 67,878 examples produced in total by the end of 1950, that eliminates the possibility of the first digit representing the year as Unit 074983 could not have been the 74,983 example produced in 1950. Unless of course there were non-continuous serial number blocks being used.
LOL, I was already 99% sure my suggestion was wrong. Found a H model that ser number started with 2, speaker date code was in '53.
Top |
Mr. Detrola
Post subject: Re: What a difference 125,412 can make Posted: Nov Wed 07, 2018 4:40 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 26923 Location: Detroit, MI USA
Has anybody given thought to the possibility that the serial numbers are consecutive for ALL Zenith radio production in a given model year, but are not necessarily consecutive for any given model? In other words, if you had 4 assembly lines and 20 radio models, you might run assembly line "A" building one model for a week, then run a totally different model the next week on the same line. That would run through a lot of serial numbers in a hurry but there would also be gaps in the sequences within any given model number.
_________________ Dennis
Top |
Bugman
Post subject: Re: What a difference 125,412 can make Posted: Nov Wed 07, 2018 4:57 pm |
Joined: Mar Sat 14, 2009 5:56 pm Posts: 4446 Location: VA 22602
I plan to pull data from three G500's I have on hand to compare information. I have two chassis' that appear to have numeric serials only and one that has the "J" prefix. On my examples. the numeric serials are stamped into the chassis and the "J" serial is on a paper label. If you look at earlier serial number issues on other radios from Zenith, you will note breaks in number series that were applied to other models. That would probably indicate serials were issued consecutively and when one chassis production ceased, another took up the next series and when production is resumed, the next number series was started leaving an apparent gap. It's too bad that the serial tag was just an applied paper label that would readily fall off. Does someone have a chassis with a stamped serial that matches a paper label?
_________________ I'm not a hoarder, I'm a caretaker of scarce commodities
Top |
35Z5
Post subject: Re: What a difference 125,412 can make Posted: Nov Wed 07, 2018 5:13 pm |
Member |
Bugman wrote: Does someone have a chassis with a stamped serial that matches a paper label? In banging around on net I did locate one that had sticker and stamp(unfortunately I don't remember where). Sticker began with letter that wasn't on chassis but numeric digits did match.
Top |
Bugman
Post subject: Re: What a difference 125,412 can make Posted: Nov Wed 07, 2018 5:21 pm |
Thank you, Tom. I wonder if the "J" was the regular prefix for the G500? I will be looking at my chassis with the paper label more closely for a stamped number. I just hadn't thought of it before this discussion. I hope to dig out the three sometime today after I take care of the wifely assigned chores. I plan to pull numbers off the parts to try to date them.
Top |
Bugman
Post subject: Re: What a difference 125,412 can make Posted: Nov Thu 08, 2018 3:34 pm |
I looked at my G500's and the results are very inconclusive. I haven't pulled any of the chassis recently and I don't recall if the radio assembly date was stamped on the chassis shelf as was done in many of the later ZTO's. The only consistently dated part readily accessed is the speaker assembly so I took the numbers from them. 1) S/N 188835 (no S/N sticker): Speaker stamp - 343043, installed Oct 1950 or later. 2) S/N 264489 (no S/N sticker): Speaker stamp - 343101, installed Jan 1951 or later. IF can stamped 198051, manufactured Dec 1950. 3) S/N J-376899 (no stamped S/N): Speaker stamp - 343015, installed Apr 1950 or later. Difference between #1 & #2 serials is over 75,000 and #2 & #3 is over 112,000, the difference between #1 & #3 is over 187,000. I'm guessing dating will be a very hazy guestimate on anyone's part. Were the "J" the initial issues of the G500? The earliest dated speaker was in the J-376899 chassis and the later issued speakers were installed in the chassis' lacking a sticker and with a lower serial number sequence. Does anyone have any input that may reveal a way to date the G500's? For the future I intend to make notes on all my ZTO's that include any stamped dates and date codes to see if anything can be used to indicate production/assembly dates of the units.
Top |
Martin Blankinship
Post subject: Re: What a difference 125,412 can make Posted: Nov Thu 08, 2018 10:31 pm |
Member |
Here is data I compiled from photos, etc. over the last eight years or so. I separated serial numbers containing the "J" prefixes from the serial numbers without J's. This is because those without the "J" have an embossed serial number, and the RETMA date code data indicates that each series was not manufactured concurrently-- the J's appear to have produced first, followed by the embossed serials.
Serial numbers collected in my database also show that there were production runs of other chassis types and models interspersed in the larger gaps in the above listed G500s, in the same practice starting with the 1936 Zenith model line. I have not included that data here, but have indicated breaks where this occured, using five asterisks.
"YYYYWW" denotes year (4 digits) followed by week of that year (2 digits) derived from the RETMA numbers, usually from the speaker, but sometimes from the tuner, or IF cans. EMB=embossed ser #, NO SP=no speaker, FR CHAS=from chassis only--i.e.: no cabinet.
SER # .........YYYYWW* ........NOTES J101435 194928 J102243 194928 J103248 J103435 J103502 194932 J103558 194933 J103704 194933 J103817 195102 SPEAKER MUST HAVE BEEN REPLACED J104065 194933 SN STICKER J104073 194933 SER STICKER J104435 194933 J104544 J104660 194934 J106240 194935 J106731 SER STICKER J107053 J107354 194927 J107407 194931
***** J173124 194939 J174931 194940 J177334 194947 J177674 STICKER J177710 194947 SN STICKER J177805 194946 J177815 194947 STICKER SER TAG J177888 194947 SN STICKER J177898 194947 SN STICKER
***** J198233 194939 J198638 194939 SER STICKER J198868 194939 J199642 194948 J199701 194947 J200159 194948 J200469 ? J200698 194943 SN STICKER J200922 194943 SN STICKER J201413 194949 J201450 194948 J201463
***** J215630 194948 J216233 194951 J216544 194950 J216778 194951 J217171 194951 J217739 194949 STICKER SER TAG J218558 194951
***** J242115 SN STICKER J242151 194950 J242236 194950 SER STICKER J242483 194950 J242676 NO SP J242781 194943 J243054 J243101 194949 J244270 194948 J244513 195001 J244901 194949 J245277 195001 J245437 195003 SN STICKER J245820 194942 J245829 194950 J246277 195001 J246924 195003
***** J257059 J257112 195004 J257207 195004 J257227 195004 J257227 195001 J257563 195004 SER STICKER J257846 J258732 195004 J259171 195004 J261318 195004 J261342 195007 J267161 195012
***** J272409 195007 J272724 STICKER J272922 195007 J273137 195010 SER STICKER, UL. J273555 J273704 195010 J273868 195008 J273999 195010 J274262 195010 J274720 195012 J275034 195012 J275196 J275424 195010 J275485 195004 J275590 195012 J275679 195004 J275698 195012 SN STICKER J275770 195004 J276031 195012 J276670 195007 J276761 195012 SN STICKER J277003 195010
***** J317506 194951 J"3"?
***** J372653 195014 J374689 195012 J374691 195012 J375456 195010 J375460 195003 J375650 195012 SER STICKER J376077 195014 J376345 J376460 195003 J376473 195004 J376827 195015 J376874 195004 J377225 195015 J377669 195004 STICKER SER TAG J377753 195016 J378125 195003 J378509 SN STICKER J379198 195003 J379203 195003
***** 36264 195015 EMBOSSED SN
***** 61675 62496 195025 70751 70981 195026 71774 195025 73929 195033 74019 195032 74644 195034
***** 137307 195036 139444 195038 FR CHAS EMB STAMP. UL STICKER 140494 195038
***** 177514 195041 184046 195044 185774 195046 186541 195047 FR CHAS EMB STAMP 186556 195043 UL STICKER 186909 195049 189002 195044 FR CHAS EMB STAMP. UL STICKER 191071 195034 FR CHAS EMB STAMP
***** 227324 195037 228738 195046 229999 195051 231661 195048 236950 EMBOSSED SN
***** 244526 195007 244778 195025
***** 258575 195104 FR CHAS EMB STAMP 259658 195104 260347 195104 261003 Verified sn 9/10/17. 261724 195104 261978 195104 262112 195104 262278 195104 262524 195104 266952 195108 268549 195110 268680 195048
***** 283128 195106
***** 332902 195048 FR CHAS EMB STAMP
I left out a couple at the end that appeared to have serial numbers intermingled with the H500 series. This is by no means every G500 I have encountered-- rather, it lists only those that I was motivated enough to record. I have listed only those that had legible serial numbers.
Top |
Bugman
Post subject: Re: What a difference 125,412 can make Posted: Nov Fri 09, 2018 2:10 am |
Thank you for your post, Martin. When you have enough serial numbers with dated parts a pattern does emerge. There are a few anomalies but that would be due to some parts being used out of production sequence which would be likely with the volume of the radios being produced. I’ll keep your list, insert my serials and add any that I may encounter in the future.
Top |
Users browsing this forum: No registered users and 29 guests |
