It is currently Apr Tue 07, 2020 9:10 pm
 Post subject: Philco power transformer
PostPosted: Nov Fri 09, 2018 11:06 pm
I have a Philco power transformer that is confusing. It is part # 32-8248 It has 2-white 2-Black 2 yellow 2-Red 2 yellow 1-green 1- brown and 2- Blue wires. I have searched to find what the wires represent primary, secondary etc. I ohmed out all the wires and the best I can figure still don’t add up? Can anyone help me with this? The transformer looks very clean.
 Post subject: Re: Philco power transformer
PostPosted: Nov Sat 10, 2018 12:11 am
That does not seem like an ordinary power transformer.
Post the resistance readings, and a light might come on. When you measure resistance, start with a lead, and then measure to every other lead**. This tells us where there are tapped windings as opposed to individual ones.
**Once you find a pair, you don't need to repeat this for all other wires. Example; suppose wh #1 reads 10 ohms to wh #2, and open to all others. You don't need to repeat for wh #2.
PostPosted: Nov Sat 10, 2018 12:14 am
I posted this originally to your earlier identical post...
Just a guess based on "common usage"...
The 2 black/yellow should be the primary.
The 2 red/yellow should be the high-voltage secondary.
One of the other leads (brown?) should be the center-tap of that winding.
The 2 blue wires should be the 5-volt filament winding.
The 2 white wires should be a 6.3-volt (or other) filament winding.
The 1 green wire should be an inter-winding shield, connected to chassis.
You can confirm this by connecting one (1) volt to the black/yellow wires and measure the voltages on the other windings. The voltages should be about 1% of the normal values.
PostPosted: Nov Sat 10, 2018 12:17 am
Leigh; You're reading the colors differently than I did----but your version makes more sense. OP can tell us which is right
PostPosted: Nov Sat 10, 2018 11:34 pm
.. Philco Everyday Elecronics Reference Manual. 1952
Why is this in Hints & Kinks?
Edit: Secondary Voltages here...
https://www.worthpoint.com/worthopedia/ ... -427642272
unverified... :)
Post New Topic Post Reply  [ 5 posts ]  Moderator: Chuck Schwark
