It is currently Apr Fri 03, 2020 4:25 am
 Post subject: Motorola wafer?
PostPosted: Jan Wed 23, 2019 12:09 am
Hi all,
Does anyone know of a way to replace this K3 "wafer"cap? Got a slightly weak left channel on this Motorola HS-899 three channel amp. Started testing with the preamp and signal is good into the volume control, but starts to fall as it goes into the 12AX7A and then remains steadily weaker......
Cheers, Steve
Sometimes discussing the wrong path leads you down the right one.....
 Post subject: Re: Motorola wafer?
PostPosted: Jan Wed 23, 2019 12:38 am
That's called a "couplate", an early attempt at reducing assembly cost by aggregating parts, sort of like a passive integrated circuit. You can make your own from scratch using discrete components mounted on
a piece of "anyboard" cut to size. It's all audio frequency so layout is not critical.
PostPosted: Jan Wed 23, 2019 2:04 am
Jeez! I wouldn't know where to start!
Cheers, Steve
PostPosted: Jan Wed 23, 2019 2:11 am
Think of it as an improvised circuit board. You cut a small perforated circuit board or poke holes on a stiff piece of plastic sheet. Mount/solder the components (4 capacitors, 2 resistors) together on to the board based on the schematic.
Are you certain this couplate is the problem with your set? This looks like something that changes tone as you change volume.
PostPosted: Jan Wed 23, 2019 4:32 am
Four capacitors - two resistors. (use 1/2 watt resistors).
100mmf equals 100pF
50mmf equals 50pF
0.0025μF equals 2500pF
0.008μF equals 8000pF
image: Philip Nelson
From→ Replacing the Vertical Stage Couplates. (Predicta Television).
https://www.antiqueradio.org/PhilcoH341 ... vision.htm
Capacitor uF - nF - pF Conversion Chart
https://www.justradios.com/uFnFpF.html
oh... your Couplates may be OK... :)
PostPosted: Jan Wed 23, 2019 5:31 am
Don't kill the couplate yet. May not be the cause of low volume.
PostPosted: Jan Wed 23, 2019 6:04 am
I'd be very surprised if that was the problem, but it's not impossible. Couplates in that type of circuit are very reliable.
As already demonstrated, they are very easy to duplicate when you know all the parts values.
PostPosted: Jan Wed 23, 2019 3:25 pm
Why not disconnect it entirely? Then see if the audio fades. Craig
PostPosted: Jan Wed 23, 2019 4:10 pm
Wow! Thanks!
Cheers, Steve
PostPosted: Jan Wed 23, 2019 4:13 pm
No, not yet.
Was figuring out my options, going to disconnect, bypass, bass treble section to see if thats dragging down the audio.
Cheers, Steve
Post New Topic Post Reply  [ 10 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: devilsmist, mhuston26, Usually Lurking and 13 guests
