It is currently Feb Wed 19, 2020 1:47 am
 Post subject: Marantz cassette machine: need DRIVE belts
PostPosted: Feb Sun 24, 2019 5:40 pm
I've just acquired a Marantz 5010B cassette machine, great unit and in v.g. condition... except not used for over 10 years; the two drive belts had "liquefied"... a terrible mess! Now cleaned up.
I've downloaded the 5010B manual from Hi-Fi Engine... Belts are:
Flat motor belt: Ref. Designation: 850N, Part number: 4380264012
Round (?) TMS (?) belt: Ref. Designation: 851N, Part number: 4380264022
Are there any generic belts for this unit? e.g. the flywheel drive belt is about 1/4 inch wide and 13 inches at "operating stretch" (my term, measured with string!) and the TMS belt is likely round cross-section, about 5 1/2 ins ditto. I presume both un-stretched lengths would be about 10% less.
They both look like easy slip-on installations...
Now I need to find a supplier! Can anyone advise me from where to get either Marantz or generic drive belts? Thanks for all replies.
Cheers,
Roger
PS. Small belt driving the tape counter looks OK.
Roger Jones,
Thornhill, Ontario
 Post subject: Re: Marantz cassette machine: need DRIVE belts
PostPosted: Feb Sun 24, 2019 6:07 pm
Wow. That one turned to dinosaur goo, didn't it.
Back when I used to do a lot of mechanical audio component rehab, I would find most belts I needed at Newark (then was MCM). They still sell belts, but I the selection of inventory has reduced drastically over the past couple decades, for probably obvious reasons.
Give then a try.
PostPosted: Feb Mon 25, 2019 4:51 pm
According to my PRB Crossline the belts needed are FRX11.3, SCX4.6, SCY5.2
PostPosted: Feb Mon 25, 2019 8:37 pm
Thanks, added to my parts number list. Still looking...
Roger
Roger Jones,
Thornhill, Ontario
PostPosted: Feb Mon 25, 2019 9:17 pm
Roger
PS. I've just inquired at:
A!-Electronic Parts
196 North Queen St.
Toronto, Ontario
M9C 4Y1
Tel: (416) 255-0343
Fax: (416) 255-4617
E-mail:
email@a1parts.com
No reply yet...
Roger Jones,
Thornhill, Ontario
PostPosted: Feb Mon 25, 2019 10:55 pm
I have used this site in the past and have never had a problem
https://www.vintage-electronics.net/ama ... tkits.aspx
Jim
KE8GMW
"AC volts and DC volts and little lamps and lities..."
PostPosted: Feb Tue 26, 2019 7:32 am
I've got a 4025 that probably needs belts. Thanks for that link.
I'm right 97% of the time. Who cares about the other 4%!
PostPosted: Feb Tue 26, 2019 4:51 pm
I have used them as well, several times. Everything was good quality and fit correctly.
PostPosted: Feb Thu 28, 2019 12:46 am
Jim and Don, may thanks for link. A1-Electronics (Toronto) says it has them, so does a friend-of-a-friend near Toronto.
Trying to optimize time, cost (I have to pay in 75 cent CAN$'s!), mailing and travel!
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
PostPosted: Feb Thu 28, 2019 1:58 am
x2, have ordered many belts from Bob there for Marantz decks, good guy.
"It's amazing what you can accomplish when you throw safety out the window", Brent Butt
PostPosted: Feb Thu 28, 2019 3:04 am
https://www.turntableneedles.com/Rubber_Drive_Belts-Tape_Decks_Turntables
I've purchased from this vendor twice and been happy with the product, speed of shipping, and price. Although the exact part numbers you mentioned do not come up on the site's search engine for Marantz, the numbers it does list are very close. 4380264012 comes up as 4380264010, and 4380264022 comes up as 4380264020. That's where I'd start, and verify carefully the description against your own length measurement. There is a huge assortment of belts, I'm sure there is something that will fit perfectly.
I have no affiliation with the site.
-Richard
PostPosted: Mar Tue 05, 2019 4:21 pm
Quick update...
New belts installed (sourced by a good friend, Radiotech_7 on ARF... many thanks!)
Belts work, electronics good, but pinch wheel hardened and shiny... no tape grip, bad wow.
"These things are sent to try us."
Working on it...
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
PostPosted: Mar Tue 05, 2019 4:26 pm
If you don't find a NOS one, there are a number of pinch roller and phono idler rebuild outfits on the web. There's still hope. :)
PostPosted: Mar Tue 05, 2019 9:29 pm
I have had good luck with Rubber Drive Cleaner / Restorer from Vintage-Electronics.net .
PostPosted: Mar Tue 05, 2019 9:55 pm
Thanks. Have sent them a request.
Cheers,
Roger
EDIT: Got a reply... they don't sell pinch rollers. Asked about "restorers"... not heard back yet.
Roger Jones,
Thornhill, Ontario
PostPosted: Mar Tue 05, 2019 11:50 pm
This guy does a great job...
http://www.wjoe.com/vintageandantiques.htm#mara
I don't see your Marantz model but you might contact him.
I bought a set for a Panasonic last year, in addition to very competitive pricing he furnished a step by step illustrated installation guide. I'd have been in trouble without it.
Also, be careful with the liquefied belts. Clean out the tar carefully with alcohol before it gets everywhere. I'm not sure how I know this but it's easy to drop a blob on the floor then track it onto the carpet.
Tim
PostPosted: Mar Thu 07, 2019 5:13 pm
Tkilboy wrote:
... Also, be careful with the liquefied belts. Clean out the tar carefully with alcohol before it gets everywhere... Tim
Iso-propyl alcohol did not work. Nor did "Googone". However, "Goof off" worked very well. Yes, liquefied rubber is a potential disaster... I learned that quickly and did not make any serious handling mistakes, but it did take a day to get a couple of black marks off my hands...!
Cheers,
Roger
PS. I'm now looking into pinch-roller rubber surface conditioner... hopefully to make it grip the tape.
Roger Jones,
Thornhill, Ontario
PostPosted: Mar Thu 07, 2019 8:53 pm
I've tried various rubber revitalizers on audio and video cassette deck rollers and idlers over the years and they are at best a stopgap measure to evaluate the rest of the mechanism to determine whether the overall repair will be worthwhile.
While these chemical treatments do somewhat work on shiny rubber, a gentle scrubbing with an emery board or other abrasive, followed by cleanup with alcohol, works just as well.
if the rubber has gotten firm at all, which you said yours has, trying to "renew" it is a complete waste of time and effort. This works about as well as roughing up the surface of a steel roller and expecting it to grip the tape. The reason a rubber roller grips is because it bends, around the capstan. When they lose their elastomeric properties (pliability), replacement is the only viable option.
just my 2 cents...
PostPosted: Mar Fri 08, 2019 7:09 am
just my 2 cents...
I like to use it soften up the rubber then, as you mentioned, gently roughen it up with some 400 or 600 grit paper.
PostPosted: Mar Fri 08, 2019 11:46 pm
Vin Tageman wrote:
... if the rubber has gotten firm at all, which you said yours has, trying to "renew" it is a complete waste of time and effort. This works about as well as roughing up the surface of a steel roller and expecting it to grip the tape. The reason a rubber roller grips is because it bends, around the capstan. When they lose their elastomeric properties (pliability), replacement is the only viable option....
Very good points... indeed, it must indent around the capstan over a small angle to work. I rechecked the rubber pinch roller... edges are softer than I first thought. I might as well try surface treatment, but whatever happens, I will still replace it as soon as I can find a new one.
Cheers,
Roger
EDIT....PS. I am pursuing this through our "WTB" section. R.
Roger Jones,
Thornhill, Ontario
