Author |
Sal Brisindi
Post subject: Re: We're back ... What happened. Posted: Mar Thu 14, 2019 2:57 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3601 Location: Freehold NJ 07728
Top |
FStephenMasek
Post subject: Re: We're back ... What happened. Posted: Mar Thu 14, 2019 4:06 am |
Member |
Joined: Mar Sun 11, 2007 6:55 am Posts: 11242 Location: Mission Viejo, southern California
Top |
Vin Tageman
Post subject: Re: We're back ... What happened. Posted: Mar Thu 14, 2019 8:08 pm |
Joined: Aug Fri 12, 2016 1:49 am Posts: 1711 Location: Houston area, TX
egg wrote: Alan... I've just posted two links, and there is additional stuff added to the end of the URL?
→ " -="window.open(this.href);return false;
I wasn't getting that in my posts, but I am now. It gets added in the editor, after hitting Preview. Each time I hit Preview, it concatenates yet another string of: -="window.open(this.href);return false; (the editor is stripping the on click JS event tag from the beginning of the string when it appears in the Preview window, replacing it with -) And my URL's have been opening in the same ARF tab today, rather than opening a new tab like normal. No, I haven't changed my browser settings. So, for the time being, I have to right click links into a new tab.
Top |
egg
Post subject: Re: We're back ... What happened. Posted: Mar Thu 14, 2019 11:14 pm |
Member |
Joined: Jan Tue 31, 2012 1:55 am Posts: 15829 Location: Mountains of Mourne. Ireland.
Yes, it only appears if you preview or edit your message. You can delete the line completely + also delete one character to its left and then retype that character. When your message looks good... pull the trigger ... It's a new bug. lol Greg. Edit: Correct... Links are not opening in a new tab either.
Top |
Alan Voorhees
Post subject: Re: We're back ... What happened. Posted: Mar Fri 15, 2019 7:19 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8596 Location: Baguio City, Philippines
egg wrote: Alan... I've just posted two links, and there is additional stuff added to the end of the URL ?→ " -="window.open(this.href);return false;https://antiqueradios.com/forums/viewto ... 3#p2999723" -="window.open(this.href);return false;" -="window.open(this.href);return false;" -="window.open(this.href);return false;" -="window.open(this.href);return false; It's a bug. If doesn't affect the link and I'm manually removing them as I find them. A fix is in the works.
Top |
Dude111
Post subject: Posted: Mar Sat 16, 2019 11:29 pm |
Member |
Thank you Alan.... Not any reason to FORCE HTTPS on a site like this however..... (Some browsers cant connect directly to these newer certs) Both HTTP and HTTPS can run together fine..... www.cellar.org does it  (You can goto www.cellar.org OR https://www.cellar.org and you stay in that session for the time your there) They are runinng VBB I have to go thru a proxy now to get here and really there is no reason for it... (This isnt a financial site or a site that needs forced SSL) its slower going thru something.... YES I AM ON IE6 BUT THE BOTTOM LINE IS THIS SITE DOES NOT NEED FORCED SSL!! I dont wanna make anyone mad,especially you Alan... I have always loved it here.... Thank you buddy  EDIT: Heres a good thread to read about this..... This site below also NOW has HTTP and HTTPS working together (When the admin posted this thread it only had http) www.tapeheads.net/showthread.php?t=59798
Top |
criageek
Post subject: Re: We're back ... What happened. Posted: Mar Wed 20, 2019 5:11 pm |
Joined: Mar Thu 02, 2017 1:37 am Posts: 714 Location: Cedar Rapids, Iowa
Actually, I think the site DOES need to be https. Using http, I believe that when you log in your credentials are not encrypted and can be captured. Anyway, using https is just smart these days. Gaining unauthorized access to this site in and of itself isn't that big of a deal, but for someone that uses the same password for all sites (I do not...I have a unique password for each site) this could be problematic.
_________________ My name is not Craig...look closely. cr = Cedar Rapids, ia - Iowa, geek = geek
Top |
dberman51
Post subject: Re: We're back ... What happened. Posted: Mar Wed 20, 2019 7:19 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 4608 Location: Boston, MA USA
Top |
Harold Wright
Post subject: Re: We're back ... What happened. Posted: Mar Wed 20, 2019 10:25 pm |
Joined: Mar Sun 29, 2009 3:34 am Posts: 914 Location: chancellor al.
Thanks Alan. Now if I could only remember how to contribute $ to site.
Harold
Top |
wiscojim
Post subject: Re: We're back ... What happened. Posted: Mar Thu 21, 2019 12:31 am |
Joined: Sep Fri 07, 2007 2:27 am Posts: 6577 Location: Grand Chute, Wisconsin
Top |
Clay Nicolsen
Post subject: Re: We're back ... What happened. Posted: Mar Mon 25, 2019 12:51 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2267 Location: Lewiston, ID
Add my thanks as well, Alan!
_________________ The Golden Age of Hi-Fi
Top |
Alfredo_T
Post subject: Re: We're back ... What happened. Posted: Mar Sat 30, 2019 2:20 am |
Member |
I believe that this site must use https: because it is a forum that restricts posting to members, and a password is used to prove that one is an authorized user. That having been said, I wonder, what is the future of unencrypted http? I run a Linux server, as a hobby, using a very old PC. The appeal is that it is a vintage computer. Would I be stuck between either having my server be incredibly slow if I use encryption or the links not working at all for many people if I do not encrypt?
Top |
Dude111
Post subject: Posted: Apr Mon 01, 2019 7:57 am |
Member |
You can encrypt but you dont have to block HTTP sessions.....
No reason to force SSL on a site unless its a banking/financial site... (All ya do is cause potential connection problems for no reason)
This is the internet NOTHING DIFFERENT OUT HERE THAN 5 YEARS AGO!!
Top |
joemg1951
Post subject: Re: We're back ... What happened. Posted: Apr Thu 04, 2019 1:43 am |
Thank you for your extraordinary work on this website! Ib so appreciate it and enjoy searching the site for interesting ideas and information!
Top |
gateman
Post subject: Re: We're back ... What happened. Posted: Apr Thu 04, 2019 11:28 am |
Member |
Joined: Dec Thu 19, 2013 2:08 pm Posts: 708 Location: Haslet Texas
Thanks Allan, Bless your pea pickin' heart.
Top |
radiorich
Post subject: Re: We're back ... What happened. Posted: Apr Fri 12, 2019 2:14 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 11272 Location: Omak,wa,usa
Hello Alan, thanks for everything
Sincerely Rich
Top |
Electronic Memory
Post subject: Re: We're back ... What happened. Posted: Apr Fri 12, 2019 6:21 pm |
Member |
Joined: Nov Thu 11, 2010 6:03 pm Posts: 1513 Location: Pewaukee, WI
Tube Radio wrote: Alan Voorhees wrote: Perhaps we can set it up to automatically resize photos posted in the forums and link them to the original uploaded photo of what ever dimensions.
Welcome back ... Yes please do that as it's very frustrating posting a topic in DIY when the schematic is large enough to where making it 800 X 600 renders it completely unreadable. The schematic then either has to be broken up into sections or sent to interested members via email. Such a feature was not needed when Photobucket allowed free accounts to upload full photos, but since Photobucket stopped that for free accounts and is so full of ads the feature would be a welcome addition to the forums here. Wonder if it would be possible to divide the gallery up by individual usernames where each person gets a certain amount of storage space which is tied to their forum login? That would curtail the spammers. Have you tried Flickr? That is what I switched to after Photobucket instituted their ransom. Aside from the one jerk move of dropping their free storage from 1TB to 2000 photos and forcing folks like me with over 3000 to delete a large chunk of their gallery (also giving the photobucket scoundrels an idea to follow suit) they have been better than Photobucket. If you create multiple 3rd party free email accounts to sign up for multiple Flickr accounts you can bypass that 2000 limit by whatever multiple you feel like making emails for.
Top |
kb2wig
Post subject: Re: We're back ... What happened. Posted: Apr Tue 16, 2019 8:29 pm |
Joined: Mar Tue 15, 2011 8:51 pm Posts: 22 Location: Onondaga
A,
I don't log in much, but I do use the resource. Keep up the good work, and thank you,
klc
_________________ A legend in his own mind.
Top |
jgross
Post subject: Re: We're back ... What happened. Posted: Apr Wed 24, 2019 10:09 pm |
Member |
Joined: Jul Fri 29, 2016 7:01 pm Posts: 191 Location: Lafayette, LA
Alan,
Thank you for your effort. This forum is the best. This forum has helped in so many ways.
_________________ Jim Straight and Level is not my only attitude.
Top |
Dude111
Post subject: Posted: Apr Thu 25, 2019 10:45 pm |
Member |
Yes now this site is the BEST of its kind!!! (Best radio related site)
Gracious Alan!!
Top |
Who is online |
Users browsing this forum: BobWeaver and 29 guests |
