It is currently Jan Sat 16, 2021 3:39 am
 Post subject: Pioneer SX-626 SS needs warm up???
PostPosted: Mar Wed 27, 2019 9:17 pm
I have a Pioneer SX 626 receiver. When I turn it on it takes a few seconds to play; yet it is solid state. Bad power caps?
Keneye
York, PA
 Post subject: Re: Pioneer SX-626 SS needs warm up???
PostPosted: Mar Wed 27, 2019 10:17 pm
Does it have a relay?
PostPosted: Mar Wed 27, 2019 10:32 pm
No relay in that model. I would start by checking the power supply voltages, could be a bad cap there?
"It's amazing what you can accomplish when you throw safety out the window", Brent Butt
PostPosted: Mar Wed 27, 2019 11:45 pm
No relay I can see. Will test power caps. In is in the que of future projects.
Keneye
York, PA
PostPosted: Mar Thu 28, 2019 5:39 am
With volume at mid range, does the audio come on slowly and distorted (crackly, buzzing, sizzling, etc.), or does it come on abruptly with no distortion?
PostPosted: Mar Thu 28, 2019 12:44 pm
Comes on with perfect sound! Just that momentary delay like you get on a tube amp warming up. That is why it confused me. A SS receiver does not typically warm up!
Keneye
York, PA
PostPosted: Mar Thu 28, 2019 3:12 pm
A slight delay in non-relay protected, solid state amps is not uncommon. Large-value power supply filter caps used in solid state amps cannot be expected to charge up instantly. I would say your receiver is operating normally.
PostPosted: Mar Thu 28, 2019 5:26 pm
Is this a new unit to you? Has it done this as long as you've owned it or is this a new symptom? Obviously, if a new symptom, then something's not right. If it's always done it, then it's by design.
PostPosted: Mar Thu 28, 2019 9:28 pm
How long is "momentary"? Most tube amps take 15 - 20 seconds to warm up. Some are much longer if the preamp tube filaments are powered by the output tubes' cathode voltage.
PostPosted: Mar Thu 28, 2019 10:37 pm
B:  Brochure
OM:  Owner’s Manual
S:  Schematic
SM:  Service Manual. 1971
SM:  Service Manual. 1973
http://www.kallhovde.com/pioneer/Pionee ... 0page.html
PostPosted: Mar Thu 28, 2019 11:45 pm
It's operating normally. Don't look for trouble where there isn't any.
kb3wbb
PostPosted: Mar Fri 29, 2019 12:50 am
Larry, are we taling receivers or marriage?
Keneye
York, PA
