It is currently May Fri 29, 2020 2:39 pm
 Post subject: AKAI 1710 Parts supplier needed
PostPosted: Mar Tue 12, 2019 3:25 am
I recently acquired a nice clean AKAI 1710 RTR tape recorder. The capstan motor would not run. The 2 uf start/run capacitor was dead (expelled electrolytic). I replaced it with a non-polarized capacitor of the same value and better voltage rating and the motor starts and runs.
The recorder came with a demo tape that is in pretty bad shape. It is stretched and won't track properly. It comes off of the capstan/pinch roller in play mode . Also, the pinch roller looks to me like it needs replacement. It is shiny and has lumps and bumps and I want to replace it. also, the push on tape reel holders are worn out.
Where can I buy AKAI 1710 parts?
Thanks in advance.
Joe
No good deed goes unpunished - Clare Boothe Luce 1903 - 1987
 Post subject: Re: AKAI 1710 Parts supplier needed
PostPosted: Mar Tue 12, 2019 8:17 pm
your pinch roller can and should be rebuilt before you go any further.
I use Terry's and they have done a great job on several:
http://www.terrysrubberrollers.com/
I would agree with you but there's no point in both of us being wrong
PostPosted: Mar Tue 12, 2019 10:57 pm
Thanks cl350rr! I am preparing the roller for shipment to Terry. Do you know where I can get a replacement capstan drive belt? The capstan turns OK but I think it is stretched and too loose.
Joe
PostPosted: Mar Wed 13, 2019 12:01 am
I might suggest Voice of Music:
http://thevoiceofmusic.com/catalog/tape_rec_belts.asp" -="window.open(this.href);return false;
I have bought from them in the past but not R2R belts
PostPosted: Apr Mon 01, 2019 10:33 pm
Hey Joe
Check Ebay. I saw a few on there.
PostPosted: Apr Tue 02, 2019 5:05 pm
I found the belts on EBAY from seller westcoastresale.
The pinch roller was refurbished by Terry's Rubber Rollers: http://www.terrysrubberrollers.com/
I am very satisfied with both suppliers.
Joe
