It is currently Mar Mon 30, 2020 2:37 pm
 Post subject: Possible Inexpensive preamp for this little ss phono ?
PostPosted: Apr Sun 21, 2019 1:29 am
Hello all,
I don't know if anyone is like me, but I hate to throw away
things I "believe" I can cobble together for fun and function.
So, to repair another 1960's Sears record player with the
same record changer, I used the one from this little 6262.
Now I have a neat little cabinet and the SS amp. I have
rebuilt a 1950's V-M record changer and made a plinth for
it to go into the little Sears cabinet.
This SS amp needs a high output cartridge of 2 Volts, meaning
I'd have to buy a crystal cart. But, as we know they can go
bad, even it they start out good.
So, any ideas on a preamp chip circuit off the shelf I
could buy and connect to this SS amp ?
The ceramic carts I have are from 0.5 to 1 volt output
that will go into the Voice of Music.
Thanks ! Hotwax
 Post subject: Re: Possible Inexpensive preamp for this little ss phono ?
PostPosted: Apr Sun 21, 2019 2:46 pm
[url][/url]I use a Pyle P444 ... think I paid less than twenty bucks for it. Here's a link - under $16!
PostPosted: Apr Sun 21, 2019 10:04 pm
Output from a ceramic cartridge would be too much for a magnetic preamp .It will
distort . Something more like this would work better .Though you would have to
assemble it . https://www.parts-express.com/yuan-jing ... uctDetails
PostPosted: Apr Mon 22, 2019 6:18 am
That's for a stereo; his print shows only one speaker. I would suggest trying one of the LM386 assembled amp boards that are very prevalent on eBay.
PostPosted: Apr Mon 22, 2019 3:43 pm
Thanks everyone for the suggestions.
Yes, this is just an inxepensive little mono amp with
one speaker, a 1960's teenager record player.
But it would be fun to resurrect it as a working unit.
So, I'm very low knowledge on
how I would wire up such a pc board pre-amp ?
Do these need a separate power supply, et cetera ?
Hotwax
PostPosted: Apr Mon 22, 2019 7:09 pm
I would not invest too much money or time into that amplifier. It is an early solid-state design which in my experience rarely sounds good and is likely to be problematic. I recommend using your VM changer with either an earlier amplifier with vacuum tubes or a later, proper solid-state one with silicon transistors and a more modern circuit. The early to mid-1960s were a difficult time period for solid-state.
-David
PostPosted: Apr Mon 22, 2019 7:34 pm
dberman51 wrote:
I would not invest too much money or time into that amplifier. It is an early solid-state design which in my experience rarely sounds good and is likely to be problematic. I recommend using your VM changer with either an earlier amplifier with vacuum tubes or a later, proper solid-state one with silicon transistors and a more modern circuit. The early to mid-1960s were a difficult time period for solid-state.-David
Thank you David for putting that perspective out there.
I could tell there is very little power output from the amp.
I'll hang on to the cabinet, and wait for another donor amp
as you suggest.
Hotwax
PostPosted: Apr Mon 22, 2019 8:17 pm
Here's an amp module for less than $15
https://www.parts-express.com/kemo-m031 ... e--320-551
PostPosted: Apr Mon 22, 2019 8:22 pm
You can get them all day long from eBay Chinese sellers, starting at 2+ bucks for 35 watts;
https://www.ebay.com/sch/32852/i.html?_ ... c&LH_BIN=1
PostPosted: Apr Wed 24, 2019 3:19 am
That little module puts out 3.5 watts not 35 watts . Don't think those little speakers
would handle 35 watts . Did you read the specks .?
PostPosted: Apr Wed 24, 2019 6:30 am
The link shows a variety of amps. The $2+ with free shipping using the TDA8932 chip puts out 35 (thirty five) watts.
Post New Topic Post Reply  [ 11 posts ]  Moderator: Alan Voorhees
