It is currently Jul Mon 06, 2020 6:52 pm
Post New Topic Post Reply  [ 46 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: zenith 12a58 restore
PostPosted: May Tue 07, 2019 12:37 pm
I would get yourself some Mohawk medium dark walnut stain and be done with it. A quart goes a long way and you can order on line I believe. Years ago tried minwax and had problems also.
PostPosted: May Tue 14, 2019 3:19 am
Amazing work, as usual! Funny how the camera just cannot capture the depth of detail in that veneer. In person I bet that wood looks like a wood version of a hologram, where you can just see right into it as it moves as you change your viewing angle.
PostPosted: May Sat 18, 2019 2:31 pm
Another wonderful save, Fred. Great job.
Paul
...... how hard can it be?
PostPosted: May Sun 26, 2019 8:55 pm
Fred,
beautiful
Sincerely Rich
PostPosted: Jun Sun 02, 2019 1:27 am
Hey Fred, I'm just curious as to what you use to adhere the new veneer and how you get the new veneer to cooperate? Is it the adhesive that's the trick?
PostPosted: Jun Fri 14, 2019 12:39 am
Good question , I use yellow tight bond glue. I Apply thin layer of glue with a semi soft rubber roller on both surfaces that your wanting to glue and let dry or flash off meaning dry to the touch not wet any more. Then place veneer where you want it and iron on with standard iron, the heat will unlock the glue and weld the two pieces together. You can get the roller at veneer supplies store online. I don't use contact cement on any thing.
Post New Topic Post Reply  [ 46 posts ]  Moderator: Peter Go to page Previous  1, 2, 3
