It is currently Sep Sun 22, 2019 5:57 pm
 Post subject: Need recommendation for interstage transformer
PostPosted: May Wed 15, 2019 2:16 am
The General aka Pacific Radio 14 tube chassis on my bench has an open interstage transformer. One leg of the secondary is open. The transformer primary connects to a pair of 6C5 tubes in parallel. The secondary connects to a pair of 6F6 outputs in push-pull. See pic of schematic (Riders Pacific 7-10). The primary measures 30kohm, the good secondary leg is 2350 ohms. What would be a good replacement- or what should be the specs? I see a few on Ebay, but dang, they are pricey.
 Post subject: Re: Need recommendation for interstage transformer
PostPosted: May Wed 15, 2019 2:24 pm
Could you add a picture of it, with dimensions, please? And/or, is there a part number on it. I could look through my Thordarson stash and see what I've got.
Dan
PostPosted: May Wed 15, 2019 3:51 pm
There is always this:
https://www.tubesandmore.com/products/t ... tage-10-ma
The full list (more expensive ones **might** be better??)
https://www.tubesandmore.com/products/t ... Interstage
Or maybe re-wind the existing one
PostPosted: May Wed 15, 2019 4:51 pm
Here is a maybe do this. About half way down the page. "Restuffing An Interstage Transformer"
http://www.oldradiosrus.com/build.html
PostPosted: May Thu 16, 2019 12:43 am
Size is 2 3/4" mounting, 2 3/4" high, 2" wide. Marked A82VC. No brand. Size isn't an issue since it's mounted under the chassis and there's lots of room. Mostly concerned about electrical specs.
PostPosted: May Thu 16, 2019 1:49 am
You could use the extra 6C5 as a phase inverter, and eliminate the transformer.
PostPosted: May Thu 16, 2019 1:52 am
I thought of that but I think I'd need more gain. And a schematic.
PostPosted: May Thu 16, 2019 2:12 pm
Is this the right page? Thordarson
Dan
PostPosted: May Thu 16, 2019 4:45 pm
The A53C is a bit anemic, you won't get much bass through it. They were great for 5 tube 3 dialer battery sets but not for big 14 tube consoles.
I would try to find a Stancor A73C or A83C if possible or another good sized interstage.
30k on the primary seems high to me. i wonder if its on the verge of opening....
Users browsing this forum: radiorich and 5 guests
