It is currently Jan Wed 26, 2022 1:32 pm
 Post subject: RCA HJ843W combo unit
PostPosted: May Mon 20, 2019 2:30 am
Is there any RCA experts that can breakdown the model number? I think is a 68 model but that is all I know ... would love to find a brochure or specs on it .. no idea what the stereo section is rated for .. found a 67 brochure on line and the stereo specs start at 40 watts per channel all the way up to 300...any info is appreciated.
 Post subject: Re: RCA HJ843W combo unit
PostPosted: May Mon 20, 2019 11:15 am
I am not a Model Expert but here is what I found
Looks like a 1968 model, but here is the RCA model Designations, is the model number you gave the whole number ? below is all I can find
hope you can read the info in the pictures
Terry
PostPosted: May Mon 20, 2019 11:13 pm
Thanks for the info... Yes that is the whole model number, the W at the end I guess means walnut finish
Thanks again.
PostPosted: May Tue 21, 2019 1:25 am
If you want to find a schematic for this set, you will need to go by the chassis number. That is generally stamped on the back of the chassis. You may or may not find everything in one Sams. Sometimes the radio will be in a different Sams. TV chassis numbers often start with KCS for black & white and CTC for color.
PostPosted: May Thu 23, 2019 7:59 pm
The radio chassis numbers start with "RC"; they were using that designation before WWII. Back in the 1960s, manufacturers came up with wildly optimistic numbers for amplifier output wattage on consumer equipment, using terms like music power and peak music power. These numbers are far greater than the actual output in RMS watts.
PostPosted: May Thu 23, 2019 8:55 pm
RCA HJ843W = CTC28AA, RC-1223C, RK-314F, RS-215K
TV- Sams 936, Folder 2
Radio/Amp Chassis - Sams 930, Folder 7
Brian
Post New Topic Post Reply  [ 6 posts ]  Moderators: Mr. Detrola, 7jp4-guy
