It is currently Aug Fri 07, 2020 11:18 am
 Post subject: Resistor question
PostPosted: May Mon 20, 2019 1:44 pm
What wattage should this replacement be? It is 1meg.
jackson bell.pdf [42.51 KiB]
Downloaded 14 times
Kevin....
 Post subject: Re: Resistor question
PostPosted: May Mon 20, 2019 2:07 pm
1,000 ohms
On that schematic, "M" means 1,000, and "Meg" = 1,000,000
That resistor generates the negative bias for the 47---somewhere in the range of 15 to 20 volts
P =E^2 / R
Assume 20 volts:
P = 400 / 1000 = 0.4 watt. Use a 1-watt part minimum
Post New Topic Post Reply  [ 2 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: Gilligan and 24 guests
