It is currently Jan Mon 18, 2021 11:27 am
 Post subject: 1967 Olds Delco car radio # 7299583
PostPosted: May Tue 21, 2019 12:25 am
AM works, but FM has multiple signals at same time. Could this be a demodulator problem, which transistor is most suspect. I have some radio knowledge but my test equipment is Power supply and VOM. Any info is appreciated. This is my first post Thanks Dennis
 Post subject: Re: 1967 Olds Delco car radio # 7299583
PostPosted: May Thu 30, 2019 10:57 pm
Hello Dennis.
If you require service information.
Oldsmobile - AM/FM Radios 7299583/7300103 was published in Sams Auto Radio Series. Volume 42 (AR-42) April 1967
ebay - $5.00 shipped.
eBay item number: 223522860918
https://www.ebay.com/sch/i.html?_from=R ... 8&_sacat=0
Welcome aboard... :)
PostPosted: May Fri 31, 2019 3:17 am
That would be a good question for Meade (MAG) !
Do you mean that multiple stations are being received at the same time at one point on dial ? Or all across dial ?
Need a bit of clarification...
PostPosted: Jun Sun 09, 2019 12:12 am
Thanks for info I found a sams locally, now see if I can fix, Dennis
To answer Johns question garbled stations across entire band. New to this type of forum hope I did it right.
Post New Topic Post Reply  [ 4 posts ]  Moderator: Dave Doughty
