It is currently Aug Sun 18, 2019 7:35 am
 Post subject: Super cool but don’t know what I have. Golden Serenata
PostPosted: May Thu 23, 2019 2:12 am
Can’t find anything online about this phonograph. It’s a coffee table size finished all sides. Large tube amp. Called a “Golden Serenata “. Anyone out there know what this is? :?:
 Post subject: Re: Super cool but don’t know what I have. Golden Serenata
PostPosted: May Thu 23, 2019 2:16 am
Trying to figure out how to add pictures
PostPosted: May Thu 23, 2019 3:02 am
https://pin.it/7oa3g47wq5jgia
https://pin.it/coe4pov3nhrc44
Here are links to the pictures on pintrest
https://pin.it/ifng62swaoispa
PostPosted: May Thu 23, 2019 3:05 am
Here's a thread on how to upload photos.
See the post there by member "egg".
Hotwax
viewtopic.php?p=2717120#p2717120
PostPosted: May Thu 23, 2019 3:22 am
Thank you hot wax. I’ll try that tomorrow on a computer. Trying to do this on my iPhone. I did figure out how to link to Pinterest
PostPosted: May Thu 23, 2019 3:32 am
Pinterest wants me to sign up before I can see the pictures. I'm not going to do that.
PostPosted: May Fri 24, 2019 7:48 pm
PostPosted: May Fri 24, 2019 7:50 pm
PostPosted: May Fri 24, 2019 7:53 pm
I have the pictures up!! please help with Identifying this stereo. I cannot find one anywhere on line. Thank You,Thank You,Thank You,Thank You!!!
PostPosted: May Fri 24, 2019 9:11 pm
Thanks for the photos.
Whatever this is, the chassis looks very well made.
The record changer is a Voice of Music 1200 series.
Solid workhorse of a changer. Parts available when
you rebuild it here : thevoiceofmusic.com
Next step is to search for any numbers stamped on the preamp
and amplifier chasses.
Then we can do a search to see a possible manufacturer.
Hotwax
PostPosted: May Fri 24, 2019 10:28 pm
Yes it’s a solid unit. Looks like a good sized amp. The speakers are not very big. It’s finished all the way around no back. Laminate top. Definitely mid century. Has a selection knob with”radio” but no radio. Not sure where the radio would have been if it had one.
PostPosted: May Fri 24, 2019 11:23 pm
So, let us know if you find any stamped numbers on either of the chasses.
H
PostPosted: May Sun 26, 2019 3:46 pm
The amp has J 102 1. Tubes are HITACHI
PostPosted: May Sun 26, 2019 3:49 pm
Only a few paper caps in the system
PostPosted: May Sun 26, 2019 3:55 pm
Most of the caps are ceramic disc
PostPosted: May Sun 26, 2019 4:12 pm
Nothing found under the amp chassis #.
What is your level of electronics repair experience ?
At this point, I'd replace all the old wax/paper/plastic covered
and electrolytic caps.
Check resistors, tubes & OP and power transformers.
Clean all control pots.
Remove one cap at a time, check its value and replace
with new one.
Take good reference photos of the amp and preamp
chasses layouts.
The record changer & motor will need a good cleaning and
possibly new motor mounts and idler wheel.
Hotwax
PostPosted: May Mon 27, 2019 2:16 pm
I know enough to stay safe. I struggled on the last one. I bought all the parts as a kit. I was unsure of the "tin can" capacitors. they came as 4 separate caps so the Can is just there for looks. had a hard time keeping it all tidy. should have started with caps only instead of all the resistors too. I need to learn how to test components. right now I just replace them all.
Post New Topic Post Reply  [ 17 posts ]  Moderator: Alan Voorhees
