Author |
Dalton
Post subject: Re: Glossary of Online Auction Terms for Radio Hunters Posted: Jun Sat 01, 2019 12:49 am |
decojoe67 wrote: What about cracks and chips on plastic radios? You rarely see those words used. It's more like "small hairline above dial"/ "tight stress line at bottom screw hole"/ "two small fleabites on top edge" = "this is a rare catalin/transistor radio and one small crack is not going to get me to part with for $150!" Some hairlines are bigger than others!
Top |
Dalton
Post subject: Re: Glossary of Online Auction Terms for Radio Hunters Posted: Jun Sat 01, 2019 12:51 am |
Findm-Keepm wrote: Shipping: Fast and Free - "you want more than a cereal box wrapping this radio?" "Ante up some big bucks - I don't pack for a living, you now....." I actually got a cereal box once... generic cereal, at that!
Top |
Braithwaite
Post subject: Re: Glossary of Online Auction Terms for Radio Hunters Posted: Jun Sat 01, 2019 1:54 am |
Joined: Nov Sun 04, 2007 6:01 am Posts: 3358 Location: Redding, CA
OldWireBender wrote: You forgot the old gym socks "for extra padding". John Gym socks? Be thankful. I received a radio well packed with salvaged foam sheet littered with many used feminine sanitary pads. There should be a law.... Norman
_________________ "No home is complete without music" - Capehart Sound Amplifying and Distributing Systems
Top |
decojoe67
Post subject: Re: Glossary of Online Auction Terms for Radio Hunters Posted: Jun Sat 01, 2019 2:16 am |
Member |
Joined: Feb Thu 17, 2011 11:27 pm Posts: 13220 Location: Long Island, N.Y.
Dalton wrote: decojoe67 wrote: What about cracks and chips on plastic radios? You rarely see those words used. It's more like "small hairline above dial"/ "tight stress line at bottom screw hole"/ "two small fleabites on top edge" = "this is a rare catalin/transistor radio and one small crack is not going to get me to part with for $150!" Some hairlines are bigger than others! The point is it's a "CRACK" or a "CHIP" however minor or major. Of course sellers don't want to write either of those words because it's poison for a plastic set, but it actually doesn't soften the blow.
Top |
Dalton
Post subject: Re: Glossary of Online Auction Terms for Radio Hunters Posted: Jun Sat 01, 2019 3:35 am |
Dutch Rabbit wrote: "refinished"--three coats of GLOSS poly with runs, drips, and bubbles, perhaps a stray brush bristle too. most likely there are stains on the speaker grill cloth or the dial bezel b/c it was too much effort to remove them during the "restoration".
"new speaker grill cloth"--rubber backed furniture upholstry stapled to the baffle, but only using the wrong sized staples so they punch thru the baffle and destroy the wood in the front of the radio.
steve Amateurs (such as myself) are best advised to leave restoration to a pro. At least on valuable radios... find a nice cheap set to learn on.
Top |
Dalton
Post subject: Re: Glossary of Online Auction Terms for Radio Hunters Posted: Jun Sat 01, 2019 3:37 am |
Braithwaite wrote: OldWireBender wrote: You forgot the old gym socks "for extra padding". John Gym socks? Be thankful. I received a radio well packed with salvaged foam sheet littered with many used feminine sanitary pads. There should be a law.... Norman OMG
Top |
Dalton
Post subject: Re: Glossary of Online Auction Terms for Radio Hunters Posted: Jun Sat 01, 2019 3:38 am |
decojoe67 wrote: Dalton wrote: decojoe67 wrote: What about cracks and chips on plastic radios? You rarely see those words used. It's more like "small hairline above dial"/ "tight stress line at bottom screw hole"/ "two small fleabites on top edge" = "this is a rare catalin/transistor radio and one small crack is not going to get me to part with for $150!" Some hairlines are bigger than others! The point is it's a "CRACK" or a "CHIP" however minor or major. Of course sellers don't want to write either of those words because it's poison for a plastic set, but it actually doesn't soften the blow. Understood!
Top |
Dalton
Post subject: Re: Glossary of Online Auction Terms for Radio Hunters Posted: Jun Sat 01, 2019 3:44 am |
OldWireBender wrote: "Worked the last time I plugged it in." Uh, about 1965, if I remember correctly. It hummed and smelled pretty bad so I never used it again. John I have purchased a few hummingbirds.
Top |
Dalton
Post subject: Re: Glossary of Online Auction Terms for Radio Hunters Posted: Jun Sat 01, 2019 3:46 am |
Zenith Royal wrote: "It may work I don't know we live out here in the country and there are no radio stations to test it." And of course they're asking $500 or best offer. "It came from my grandfather 's estate, and he took good care of everything. " "From my personal collection. "  I love this one. All the radio stations have gone away!
Top |
Dalton
Post subject: Re: Glossary of Online Auction Terms for Radio Hunters Posted: Jun Sat 01, 2019 3:48 am |
Here's a good one - "in original box" translation- has box, does NOT have any adapters or accesories that were once in the box.
Top |
palegreenthumb
Post subject: Re: Glossary of Online Auction Terms for Radio Hunters Posted: Jun Sat 01, 2019 4:18 am |
Member |
Joined: Apr Sun 01, 2012 9:55 pm Posts: 10687 Location: Seattle, WA
One of the most honest ones I've seen in a few ads is, "It seems to want to work."
Translation in my mind: "We tried it, it lights up, but we only got static."
I think I've even said it once or twice about radios I bought!
_________________ Rodney -- KG7EPW Measure it with a micrometer, mark it with chalk, cut it with a chainsaw.
Top |
tomb123
Post subject: Re: Glossary of Online Auction Terms for Radio Hunters Posted: Jun Sat 01, 2019 4:49 am |
Joined: Feb Fri 01, 2019 11:35 pm Posts: 275 Location: Riverside Ca. 92504
Thanks to all for the radio buyers guide . This should be put into Webster's dictionary. I always like the adds that say untested and I do not believe them, unless I see in the pictures an complete crappy cord that would shock someone when plugged in that has not been moved out of the radio since stored. I have brought several radios that had the cord cut and they were the problem ones to fix. Tom
Top |
Dutch Rabbit
Post subject: Re: Glossary of Online Auction Terms for Radio Hunters Posted: Jun Sat 01, 2019 5:05 am |
Member |
Joined: May Sun 13, 2012 8:12 pm Posts: 12729 Location: Central PA 16801
just saw one on ebay today:
"one of a kind"== common as dirt.
steve
_________________ You have enemies ? Good. That means you've stood up for something, sometime in your life. -Churchill
Top |
Dalton
Post subject: Re: Glossary of Online Auction Terms for Radio Hunters Posted: Jun Sat 01, 2019 5:15 am |
palegreenthumb wrote: One of the most honest ones I've seen in a few ads is, "It seems to want to work."
I think I've even said it once or twice about radios I bought! It gets an,"A" for effort! LOL
Top |
Dalton
Post subject: Re: Glossary of Online Auction Terms for Radio Hunters Posted: Jun Sat 01, 2019 5:17 am |
tomb123 wrote: Thanks to all for the radio buyers guide . This should be put into Webster's dictionary. I always like the adds that say untested and I do not believe them, unless I see in the pictures an complete crappy cord that would shock someone when plugged in that has not been moved out of the radio since stored. I have brought several radios that had the cord cut and they were the problem ones to fix. Tom Yep. Someone plugged them in and a fireworks display ensued.
Top |
Dalton
Post subject: Re: Glossary of Online Auction Terms for Radio Hunters Posted: Jun Sat 01, 2019 5:19 am |
Dutch Rabbit wrote: just saw one on ebay today:
steve or - "made by fly by night company"
Top |
fifties
Post subject: Re: Glossary of Online Auction Terms for Radio Hunters Posted: Jun Sat 01, 2019 8:05 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 33311 Location: SoCal, 91387
"Upcycled"...Gutted, painted hideously, and turned into a laundry hamper or fish tank holder.
_________________ \\\\\\\\\\\\\\\\\\\\\\\\He Who Dies With The Most Radios Wins//////////////////
Top |
Dalton
Post subject: Re: Glossary of Online Auction Terms for Radio Hunters Posted: Jun Sat 01, 2019 11:16 am |
fifties wrote: "Upcycled"...Gutted, painted hideously, and turned into a laundry hamper or fish tank holder. I haven't sen this one yet, but I'm on the lookout!
Top |
decojoe67
Post subject: Re: Glossary of Online Auction Terms for Radio Hunters Posted: Jun Sat 01, 2019 1:15 pm |
Member |
Dalton wrote: Understood! An example is a Plaskon '36 FADA tabletop radio I got years ago. I wrote about it here and when collectors read that it had many tiny hairline cracks (common on these), they practically told me it's worthless. Although I was surprised, I learned just how picky collectors can be with these plastic sets. I know it isn't "worthless", but it's worth just a percentage of one that's in excellent shape.
Top |
Dalton
Post subject: Re: Glossary of Online Auction Terms for Radio Hunters Posted: Jun Sat 01, 2019 4:22 pm |
decojoe67 wrote: Dalton wrote: Understood! An example is a Plaskon '36 FADA tabletop radio I got years ago. I wrote about it here and when collectors read that it had many tiny hairline cracks (common on these), they practically told me it's worthless. Although I was surprised, I learned just how picky collectors can be with these plastic sets. I know it isn't "worthless", but it's worth just a percentage of one that's in excellent shape. Still a very nice set with the Plaskon. I agree though, I now come here and ask questions before buying. MOST of the time! : )
Top |
