Page 1 of 1
[ 14 posts ] |
Author |
rhrailfan
Post subject: Allied A-2515 questions Posted: May Fri 31, 2019 12:43 am |
Joined: May Thu 09, 2019 12:06 am Posts: 193 Location: Charlotte NC
Why do I have to keep the RF gain turned up to the max to be able to hear anything? If I turn it down just the smallest amount the sound goes away.
Top |
wazz
Post subject: Re: Allied A-2515 question Posted: May Fri 31, 2019 3:03 am |
Member |
Joined: Jun Wed 08, 2011 2:33 am Posts: 9520 Location: Ohio 45177
The RF gain is a pot across the antenna input system. I had the opposite problem with mine. A fully efficient full sized dipole on say, 40 meters was unable to reduce the signal levels very much in that receiver. Perhaps there was parasitic RF coupling around or thru the pot with the strong signals from a resonant antenna. OR maybe the fact I installed a 40673 MOSFET RF amp to replace the blown mosfet was an issue as it might have been higher gain. They should have used their RF gain control to adjust bias on one of the gates of the RF mosfet amp instead of that wretched pot across the antenna scheme. Did you make sure your antenna protection diodes were good? I cannot really go back and check much as after I loaded the manual onto a disc for the one I sold, I deleted it from my archives.
_________________ Reddy Kilowatt says; You smell smoke? Sorry about that!
Top |
rhrailfan
Post subject: Re: Allied A-2515 question Posted: May Fri 31, 2019 3:11 am |
I will have to check the diodes
Top |
wazz
Post subject: Re: Allied A-2515 question Posted: May Fri 31, 2019 11:37 pm |
Member |
Since the diodes are back to back across the antenna terminals, they will read between .2 and .5 volts drop each way in a diode test. Not short circuit. Presumably they were put in to prevent blowing the mosfet from static discharge or too much RF from a transmitter.
Top |
rhrailfan
Post subject: Re: Allied A-2515 question Posted: Jun Wed 05, 2019 2:15 am |
I am guessing check the diodes with the power off correct?
Top |
rhrailfan
Post subject: Testing a non-working S-Meter Posted: Jun Wed 05, 2019 2:29 am |
The one on my Allied A-2515 does not work. Is there way to test to see if it is the meter or something else causing it not to work?
Top |
reeves03
Post subject: Re: Testing a non-working S-Meter Posted: Jun Wed 05, 2019 2:46 am |
Member |
Joined: Jun Sat 18, 2011 3:36 am Posts: 2341 Location: Milton, FL 32570
I took the meter out of my CB and used a 1k resistor and a current limited power supply to test the swing on my s meter.
I think you could probably use a battery and a potentimeter to do the same thing.
Jason
_________________ Thanks, Jason N1EBC
Top |
Jthorusen
Post subject: Re: Testing a non-working S-Meter Posted: Jun Wed 05, 2019 2:52 am |
Member |
Joined: Nov Mon 02, 2009 7:01 am Posts: 3848 Location: Lincoln City, OR 97367
Greetings to rhrailfan and the Forum:
Yes. I was unable to download more than the schematic on the internet, but at a guess from the component values, the meter is a 0-1 mA meter.
Disconnect the meter leads from the radio circuitry. Place a 10K resistor in series with a 9 volt battery and connect across the meter terminals. The meter should deflect to near full scale. (If it deflects backwards, you have the polarity wrong.)
_________________ Jim T. KB6GM
Top |
rhrailfan
Post subject: Re: Testing a non-working S-Meter Posted: Jun Wed 05, 2019 3:52 am |
Top |
wazz
Post subject: Re: Allied A-2515 questions Posted: Jun Thu 06, 2019 2:00 am |
Member |
The manual and schematic pdfs are on BAMA but they are listed under Knight instead of Allied. Has part number of meter but not the value.
Top |
rhrailfan
Post subject: Re: Allied A-2515 questions Posted: Jun Thu 06, 2019 3:22 am |
I plan to check the meter and diodes out this weekend. Once I get my listening spot setup this will be my main radio until I get one of my Hallicrafters redone. So I want to get it working right. I wish there were some mods to make it even better.
Top |
wazz
Post subject: Re: Allied A-2515 questions Posted: Jun Fri 07, 2019 7:44 pm |
Member |
Well if it is an early version with the narrow filters that muffle AM stations, you could modify it to the later configuration where they broadened the selectivity to make AM modulation reception clearer. I think they just removed one or more of the ceramic filters. I would have to see the schematics side by side, I think both versions are out there.
Top |
rhrailfan
Post subject: Re: Allied A-2515 questions Posted: Jun Fri 07, 2019 11:17 pm |
How could I tell which version I have?
Top |
wazz
Post subject: Re: Allied A-2515 questions Posted: Jun Sat 08, 2019 2:37 am |
Member |
I found this information searching: https://www.radiobanter.com/shortwave/6 ... -rcvr.htmlThis guy claims that the later version with the wider IF for AM was called an A2515A. The narrow IF version has four metal cans on the IF strip at the back of the radio, marked MF-1 thru 4. This guy says they reduced it to two cans of ceramic filters. And removed one gain stage. I would think they would have used the same circuit board and just left the holes unused for the extra parts instead of going to the expense of designing a new board layout for a unit in production. Well you can tell if AM signals sound muffled a bit with no high tones.
Top |
Page 1 of 1
[ 14 posts ] |
Moderator: Sandy |
