It is currently Feb Mon 17, 2020 1:33 am
 Post subject: grundig Locarno 3/u
PostPosted: Jun Fri 07, 2019 12:53 am
does anybody have or know where i can purchase a service manual for a grundig locarno 3/u? I need spec's for the output power power transistors.
 Post subject: Re: grundig Locarno 3/u
PostPosted: Jun Fri 07, 2019 4:58 am
The transistors are shown on this schematic.
viewtopic.php?p=3031109#p3031109
AD161
https://www.radiomuseum.org/tubes/tube_ad161.html
AD162
https://www.radiomuseum.org/tubes/tube_ad162.html
If yours are different, they should be labeled?
Google will cross-reference them.
Edit: The CS155 schematic that I linked to on 5-20-2019 looks to be the same as this...
3/U Chassis CS155U/MS
https://www.radiomuseum.org/r/grundig_m ... 55ums.html
PostPosted: Jun Fri 07, 2019 3:23 pm
There are two, eight-page service manuals for tuner/radio chassis CS155 here...
one if French and one in German.
https://www.doctsf.com/grundig-cs-155/f35773/ori=ps
Do not purchase any literature from Cicon Electronics!
PostPosted: Jun Sat 08, 2019 2:18 pm
I second that, they are a bunch of crooks.
PostPosted: Aug Mon 05, 2019 8:42 pm
Thanks for all the info. Schematics and transistors. I figured that since I got this one free, I'd fix it. Replaced all four blown output transistors with nte155's and 131's. Installed 10 watt 15 volt zener diode, Overkill, what the heck. I had one. First 1 amp on board fuse was blown. Actually all 3 fuses were fast blow, should be slow blow. Replaced them all. Replaced six electrolytics. Main fuse was ok. Still no sound. I checked the continuity of the external speaker connection. Nothing. I bypassed them by soldering a piece of wire on each. Boom, the stereo plays clear as a bell. Am, fm and shortwave. No sense wasting deoxit on them. I don't like hooking external speakers to these vintage stereos.
Once again, thanks for the help
Post New Topic Post Reply  [ 5 posts ]  Moderator: Dave Doughty
Users browsing this forum: Ed in SoDak and 6 guests
