It is currently Aug Wed 12, 2020 4:51 am
 Post subject: Krud Kutter
PostPosted: Jun Sat 15, 2019 2:06 pm
Just to let people on here to know Kurd Kutter Gel works great. I brush it on with a acid brush. It works fast.
Kevin....
 Post subject: Re: Kurd Kutter
PostPosted: Jun Sat 15, 2019 2:28 pm
From the title I was wondering who would want to cut kurds. :) :)
But thanks! I never saw that stuff before. Looks great!
W2MDM
http://mikesradiosandstuff.weebly.com/index.html
PostPosted: Jun Sat 15, 2019 3:11 pm
I bought it at Menards
Kevin....
PostPosted: Jun Sat 15, 2019 3:19 pm
Apparently Krud Kutter is a brand name for a large family of products , from Rust-Oleum.
"The Must for Rust" is the product name within the family. It comes in both liquid and gel versions.
Haven't used it yet, but intend to try.
-Chuck
PostPosted: Jun Sat 15, 2019 3:22 pm
I dunno - maybe somebody with a scimitar?
My thanks as well - I will keep an eye out for it.
PostPosted: Jun Sat 15, 2019 3:23 pm
....active ingredient is Phosphoric Acid. Naval Jelly is the same.
KK:
www1.mscdirect.com/MSDS/MSDS00058/77918878-20141213.PDF
NJ:
archpdfs.lps.org/Chemicals/Naval_jelly_rust_dissolver_Loctite.pdf
Brian
PostPosted: Jun Sat 15, 2019 5:54 pm
I thought he was talking about people from the middle east or maybe soured milk.
Haha.
Does look good.
We are the only normal ones.
PostPosted: Jun Sat 15, 2019 6:09 pm
This works better than Navel Jelly in my opinion
Kevin....
PostPosted: Jun Sun 16, 2019 5:15 am
I've used a Krud Kutter product mixed with water and sprayed on siding. It loosens the baked on stains from dead algae or mold and so on. After 10 mins, you hose it off.
Burl Ives, RIP, oldtimer.
[:l>)
PostPosted: Jun Sun 16, 2019 2:02 pm
No doubt. And it takes FOREVER to harvest enough jelly from navels to have a useful amount of the stuff.
PostPosted: Jun Sun 16, 2019 6:22 pm
Thanks for the tip Kevin. Do you do some type of wipe or rinse to neutralize after applying?
John KK4ZLF
PostPosted: Jun Sun 16, 2019 8:41 pm
If it is real bad, I use a scotch bite pad with it. I wipe it off with a damp sponge.
Kevin....
 Post subject: Re: Krud Kutter
PostPosted: Jun Mon 17, 2019 5:20 pm
I fixed the title. I will have to try this, the regular Krud Kutter is great stuff for cleaning anything.
PostPosted: Jun Tue 18, 2019 2:02 am
I've used Kruid Kutter to remove rust before and had great success, but be careful! Unlike Evaporust you cannot leave parts soaking in it indefinitely because it's stronger and works faster than Evaporust. I forgot that I has some small screws soaking in it and left them for 2 or 3 days. When I remembered and went to remove them I found that they were nearly completely dissolved :(
PostPosted: Jun Tue 18, 2019 2:06 am
Bullfrog works very well. The acids leave a surface which will soon be covered with new rust.
https://www.popularmechanics.com/home/t ... vers-test/
PostPosted: Jun Tue 18, 2019 2:23 am
After acid treatment, the surfaces should be neutralized with an alkaline solution to prevent flash rusting. I use soap.
Post New Topic Post Reply  [ 16 posts ]  Moderators: Norm Leal, Marcc
Users browsing this forum: Dirt Bomb, lorenz200w, Marcc and 12 guests
