It is currently Feb Sat 22, 2020 4:26 am
 Post subject: Diode rectifier question
PostPosted: Jun Sun 16, 2019 11:26 pm
Hi all,
Trying to put together a little amplifier and had a question about voltage coming out of the rectifier.
The transformer HV secondary is 300-0-300VAC. There is no 5VDC winding for a standard tube rectifier so I'm using diodes.
I figured the rectified voltage (two diodes in series coming out of each leg of the HV secondary, then paired, with HV center tap to ground, would give me about 410 or 420VDC.
But I'm getting much lower than that in practice. With diodes in place, the rectified voltage is only around 265VDC to ground. There are no filter caps in place, just the rectifier.
I have no explanation for this. Does anyone?
Ted
 Post subject: Re: Diode rectifier question
PostPosted: Jun Sun 16, 2019 11:32 pm
Hi Ted,
You MUST have a proper filter in place, i.e. two electrolytic capacitors with a choke or resistor between them, to get proper DC from the supply.
PostPosted: Jun Mon 17, 2019 12:01 am
Thanks. Assumed as much.
I had seen the old guideline that solid state rectified voltage is about 1.4x the AC voltage. I did not know that was also including the filters.
Thanks.
PostPosted: Jun Mon 17, 2019 12:21 am
You need at least one filter capacitor at the output of the rectifier to get that peak voltage.
You do not need a full filter if the supply is unloaded.
PostPosted: Jun Mon 17, 2019 1:01 am
Actually the peak voltage is there. It is a half wave waveform, if you looked at it on a scope you can see that. This issue is that the waveform ( since it contains a lot of AC) fools the meter that is expecting DC. A large capacitor smooths out the waveform and charges to the peak voltage (with no load).
Tim
PostPosted: Jun Mon 17, 2019 1:26 am
The Hammond rectifier guide is very useful. It shows what you might expect for various configurations of rectifiers and transformers.
http://www.hammondmfg.com/pdf/5c007.pdf
Note: Voltages shown are with a load connected.
PostPosted: Jun Mon 17, 2019 2:33 am
Adding to the above.
The blue waveform below is what you would see on an oscilloscope. The peaks of the waveform are about 407 volts.
The red line is what a DC meter that averages the waveform will read. That is about 258 volts.
With a capacitor added, it will stay charged to near 407 volts and the meter will then read the expected voltage.
Jay
Post New Topic Post Reply  [ 7 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: Google [Bot], heatman5, nash, NumberMaj 1 and 23 guests
