It is currently Apr Wed 01, 2020 9:10 pm
 Post subject: Webster Chicago 100 - Emerson Radio Cabinet
PostPosted: Jun Tue 18, 2019 5:43 pm
I was fortunate to get this cabinet a couple of months ago, Radio works fine, and has sound. The turntable rotates for all the speeds (33-45-78). But looks like the needle is not working (I lightly rubbed it to test for sound, sorry if it is the wrong way to test it), anyone has experience replacing/changing the needle?
I also have the original manual
Turntable: Wester Chicago Model 100-1
Thank you for any help.
 Post subject: Re: Webster Chicago 100 - Emerson Radio Cabinet
PostPosted: Jun Wed 19, 2019 3:56 am
https://www.google.com/search?source=hp ... kA6d3GNYrI
This link should put you on to ''the voice of music''
I believe that if you give them the make and model number of your turntable or the cartridge number,
they can help you . If the link does not work google ''the voice of music''
Dan in Calgary
PostPosted: Jun Wed 19, 2019 4:16 am
Welcome to the forum.
Before you go any farther, has this unit's chassis been
electrically restored ?
This must be done to prevent damage to yourself and
the electrical circuits.
Minimum of all old capacitors (electrolytic and wax/paper)
must be replaced. Resistors should be checked to be
w/in specs. Tubes checked for possibly shorts.
Wiring visually checked for insulation integrity.
Hotwax
PostPosted: Jun Thu 20, 2019 2:56 pm
"But looks like the needle is not working"
Most likely the crystal cartridge.
"Before you go any farther, has this unit's chassis been
electrically restored ?"
This is necessary for sure.
And V-M site will probably suggest a P51 cartridge replacement.
Bill J.
PostPosted: Jun Thu 20, 2019 10:27 pm
Caz, HotWax, NumberMaj, thank you very much!!
I will do all of that.
As soon as I get it to work, I shall report back
Post New Topic Post Reply  [ 5 posts ]  Moderator: Alan Voorhees
