Page 1 of 1
[ 7 posts ] |
Author |
AnsonM
Post subject: Crosley 106CP Posted: Jul Thu 11, 2019 4:14 pm |
Hi all, I'm new to the group and have a question about my restored Crosley 106CP. After a move to my new house, the receiver (mainly AM Broadcast) has lost all sensitivity. If I hold my hand on or near the variable tuning capacitor the reception improves dramatically. Any thoughts on what to pursue next? Perhaps time to break out the tube tester, when I can find it! Also, I 'm looking for replacement knobs. Any suggestions would be greatly appreciated.
Anson
Top |
JnTX
Post subject: Re: Crosley 106CP Posted: Jul Thu 11, 2019 4:27 pm |
Joined: Nov Tue 14, 2017 5:09 am Posts: 3275 Location: Austin, Texas
Most likely a broken connection to the loop antenna. It should be in the bottom part of the cabinet and connect to the radio chassis with two wires.
Jay
Top |
lorenz200w
Post subject: Re: Crosley 106CP Posted: Jul Thu 11, 2019 4:29 pm |
Joined: Jan Mon 16, 2012 4:15 pm Posts: 7073 Location: Near Brandon, Iowa
Does your new house have aluminum or steel siding?
Top |
AnsonM
Post subject: Re: Crosley 106CP Posted: Jul Thu 11, 2019 6:38 pm |
Brick and frame house. The antenna assembly is intact although the insulation is breaking off in spots. I may try a different wire to see if that changes things.
Top |
JnTX
Post subject: Re: Crosley 106CP Posted: Jul Thu 11, 2019 8:10 pm |
If it is a newly built house, it may have a layer of aluminum foil in the insulation. I've found that to significantly reduce the reception in my house.
Jay
Top |
Tbone
Post subject: Re: Crosley 106CP Posted: Jul Sun 14, 2019 7:09 pm |
Member |
Joined: Jun Sun 03, 2012 12:40 am Posts: 2039 Location: Cromwell, Connecticut
That looks like what should be a good performing radio. With a loop antenna you might try turning it to see if that helps. While I like loops, unless they are made to be rotated without turning the whole set, they can be a pain. Another suggestion is to take the radio outside. If it works properly then you have your answer.
_________________ Tony
Top |
AnsonM
Post subject: Re: Crosley 106CP Posted: Jul Mon 15, 2019 4:50 am |
Done the turning and antenna checks etc. I'm talking about a local AM station too. Almost no sensitivity until I pass my hand on or near the tuning cap. The Shortwave bands seem sensitive enough however. Oh well I will keep plugging away at it. As I said, it was recently rebuilt and worked well until I moved to a new location. I'm feeling that its a tube.
Top |
Users browsing this forum: SteveD and 24 guests |
