It is currently Feb Tue 25, 2020 4:34 am
 Post subject: Can't get the back off of Zenith radio, help?
PostPosted: Aug Tue 13, 2019 10:11 pm
I unscrewed the 4 screws and the antenna screw but there's these rivets attached to a metal box, which looks like it could be an interlock. I tried pulling the rivets and pulling the whole back but I don't want to break it. What can I do?
 Post subject: Re: Can't get the back off of Zenith radio, help?
PostPosted: Aug Tue 13, 2019 10:12 pm
Are there screws underneath? Did you remove the knobs? What model Zenith is it?
PostPosted: Aug Tue 13, 2019 10:19 pm
Yes, I tried unscrewing the screws underneath but it was for the whole chassis and it was just loose in there and i still couldn't get the back off. I took all the knobs off of it also. It's a model B728F.
PostPosted: Aug Tue 13, 2019 10:26 pm
https://www.radiomuseum.org/r/zenith_b7 ... assis.html
PostPosted: Aug Tue 13, 2019 10:28 pm
Ahh, Greg to the rescue. Those two screws underneath need to come off. You may also need to take the clock knobs off.
PostPosted: Aug Tue 13, 2019 10:29 pm
That riveted box is the interlock, it should pull right out.
PostPosted: Aug Tue 13, 2019 10:38 pm
The interlock block should slide off the two connecting pins. Can you insert a screwdriver between the two pins and apply a little leverage?
PostPosted: Aug Tue 13, 2019 10:51 pm
This dude was right, I added a little more force and it slid out.
Now, does anyone know a way to lubricate the clock without having to take the whole thing out? I really don't feel like de-soldering wires. Not to mention i don't have a solder iron or solder. The clock barely runs and it makes a loud scraping sound, it needs oil badly.
PostPosted: Aug Tue 13, 2019 11:13 pm
You'll have to take the clock off and apart to lube it. It could be dirt in the movement, lack of oil in the rotor (round copper colored thing), or both.
PostPosted: Aug Tue 13, 2019 11:18 pm
What if I just spray some Wd-40 or lithium grease in there?
PostPosted: Aug Tue 13, 2019 11:36 pm
That's a Telechron movement. Most of the critical moving parts are in that copper unit, so I don't think spraying any lube inside there will help much. It IS possible to drill a hole in the sealed unit and relube it, but you're probably better off looking for a replacement. Search for Telechron rotor and you'll find tons of info.
-Jim
W6JCR
PostPosted: Aug Wed 14, 2019 12:23 am
So you will need to take the copper looking drum out of the movement. There's 2 screws on either side. The stack of metal plates that goes around it is an electromagnet and they separate. Once you pull the screws, use a screwdriver blade to slowly pull the two halves of the plates apart and remove the copper thing ( the rotor ).
Now here's how you can lube it:
A: Heat the whole drum up with a soldering iron or with a plumbing torch set to very low. Dribble a bit of oil onto the output shaft ( has a gear) the oil will probably start boiling. Let it do so for a bit, turn off heat, let it cool and apply more oil. As it cools the new oil will get sucked in. The BETTER way is to buy some clear fuel hose. I can't recall the diameter but I have a few pieces that snug right over the output shaft meaning I can fill that tube with oil and then as it boils up in the tube, I'll let it cool and there's thus more oil to draw from.
B: When you re-install make sure that the 3 little "nipples" that stick out of the bottom of the rotor are flush with the mounting surface and that the output shaft makes contact with the gears.
PostPosted: Aug Wed 14, 2019 3:24 am
Another way I have heard for lubing Telechron rotors is as follows:
  • Half-fill a clean, empty baby food jar with lightweight oil (eg. sewing machine oil) and put it in the freezer overnight.
  • Put the rotor in a double boiler on the stove, heat it up till the water is boiling, then give it a few minutes for the rotor to come up to temperature.
  • Take the jar of oil out of the freezer, then use tongs to take the hot rotor out of the double boiler and submerge it in the jar of cold oil.
As the rotor cools it will suck in oil, like Bob said.
Rodney -- KG7EPW
PostPosted: Aug Wed 14, 2019 5:28 am
Also, you will need a soldering iron, because the filter caps, electrolytic capacitors, in the radio section should be replaced.
They are old and dry and can burn out now that you are powering the radio up again.
If the rotor does not accept oil the first time, try it again. Usually oil is all it needs, but sometimes the gears and bearings are worn excessively, and a reconditioned rotor is needed. They are available because there are 1000's of clock radios and clocks that use the same unit. Another source of parts is another cheap old clock radio, and there are plenty of those. Good Luck.
Burl Ives, RIP, oldtimer.
[:l>)
Post New Topic Post Reply  [ 14 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: andjones, calmark, cwysong, davek65, dfields69, Dirt Bomb, lorenz200w, scradion, Usually Lurking and 20 guests
