Page 1 of 1
[ 13 posts ] |
Author |
Uptown
Post subject: Any idea what type of tubes these are? Posted: Aug Fri 16, 2019 4:01 am |
Joined: Apr Sat 30, 2011 2:14 am Posts: 673 Location: Mississauga, Ontario
Hello to All, I have just acquired a box of tubes from a cousin who got them from his work, they were going to be thrown out. I use radio and amplifier tubes and have never seen these tube types. I'm guessing they are transmitting tubes? If anyone can enlighten me to the use or type of these tubes it would help satisfy my curiosity, I don't have a use for them but thought they would make a cool display. Thanks for any info, Mauro
Attachments: |
Top |
Norm Leal
Post subject: Re: Any idea what type of tubes these are? Posted: Aug Fri 16, 2019 4:10 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 37563 Location: Livermore, CA
You have it right. They are transmitting tubes. Often used in the RF output stage of an amateur transmitter. Here is information on 5D22, the number seen in your photo: https://frank.pocnet.net/sheets/140/5/5D22.pdf
_________________ Norm
Top |
Jthorusen
Post subject: Re: Any idea what type of tubes these are? Posted: Aug Fri 16, 2019 4:13 am |
Member |
Joined: Nov Mon 02, 2009 7:01 am Posts: 3858 Location: Lincoln City, OR 97367
Greetings to Mauro and the Forum:
Yes, those are all transmitting tubes. The one on the far left looks like a 304TL. That is a high power triode for MF or HF work. The next one could be a 4-400 or something similar. A high power tetrode for HF work; if it is a 4-400, the plate dissipation rating is given by the last part of the number. The four means four elements; the four hundred is 400 watts plate dissipation. The Penta Labs tube is their version of a 4-250 (4 elements meaning tetrode; 250 watts plate dissipation). The last tube is an older tube; I'm sure someone will recognize it, but I do not off the top of my head.
_________________ Jim T. KB6GM
Top |
Mikeinkcmo
Post subject: Re: Any idea what type of tubes these are? Posted: Aug Fri 16, 2019 5:16 am |
Member |
Joined: Oct Sun 15, 2006 12:57 pm Posts: 6741 Location: Liberty, Missouri
Top |
Jthorusen
Post subject: Re: Any idea what type of tubes these are? Posted: Aug Fri 16, 2019 7:27 am |
Member |
Greetings to Mike and the Forum:
The last tube does indeed look like a 211 (envelope shape and brass base) but I am pretty sure that a 211 does not have a plate cap.
Top |
Clutter
Post subject: Re: Any idea what type of tubes these are? Posted: Aug Fri 16, 2019 9:10 am |
Member |
Joined: Nov Wed 09, 2011 4:07 am Posts: 669 Location: MD-DC 20855
The 5D22 is missing the ground ring. It may still work fine without it, however. It should look like the 2nd tube from the left, which looks like a 4-400A type. It's also been robbed of its plate cap- again, it should look like the 2nd tube. It would not be difficult to get hold of one- just scavenge one from a known bad 'dud' tube. The 3rd tube is also known as a 4-250A BTW.
David
_________________ Clutter
Top |
wazz
Post subject: Re: Any idea what type of tubes these are? Posted: Aug Fri 16, 2019 1:11 pm |
Member |
Joined: Jun Wed 08, 2011 2:33 am Posts: 9544 Location: Ohio 45177
In the instance of the high power tubes, lacking a transmitter to test them in, I wonder if the manufacturers offered any sort of testing service for their high power tubes back in the day? I guess some of the very high power tubes could be rebuilt back then. For commercial users. Big transmitting tubes from unknown sources are pretty much display items for most people. Unless they are new old stock or known good, and you have a project in mind.... You will need a pretty hefty power supply just to light the filaments, on most of them.
_________________ Reddy Kilowatt says; You smell smoke? Sorry about that!
Top |
Braithwaite
Post subject: Re: Any idea what type of tubes these are? Posted: Aug Fri 16, 2019 2:49 pm |
Joined: Nov Sun 04, 2007 6:01 am Posts: 3360 Location: Redding, CA
The tube at the right end is a Type 805. Base is marked as such.
Norman
_________________ "No home is complete without music" - Capehart Sound Amplifying and Distributing Systems
Top |
Dale H. Cook
Post subject: Re: Any idea what type of tubes these are? Posted: Aug Fri 16, 2019 3:54 pm |
Member |
Joined: Feb Sun 02, 2014 9:13 pm Posts: 2040 Location: Roanoke, VA
wazz wrote: In the instance of the high power tubes, lacking a transmitter to test them in, I wonder if the manufacturers offered any sort of testing service for their high power tubes back in the day? They did not. Transmitter tubes are tested by seeing how they operate in a transmitter. The transmitter tubes that can be rebuilt have metal-ceramic envelopes, not glass envelopes. Dale H. Cook, Radio Contract Engineer, Roanoke/Lynchburg, VA https://plymouthcolony.net/starcityeng/index.html
Top |
Uptown
Post subject: Re: Any idea what type of tubes these are? Posted: Aug Fri 16, 2019 10:58 pm |
Thank you for all the information. I guess I have some new display items. A great weekend to all, Mauro
Top |
Number 6
Post subject: Re: Any idea what type of tubes these are? Posted: Aug Sat 17, 2019 11:34 pm |
Member |
Joined: Jan Fri 17, 2014 7:26 am Posts: 1877 Location: In the village, 19115
The 5D22 may have gone to air, or hopefully it is just dusty. The 304TL tube may have a bad filament. You can check the specs and ohm it out with a meter.
_________________ I like things that light up, tubes, bulbs, LEDs, whatever, and things that make noise.
Top |
Tim Tress
Post subject: Re: Any idea what type of tubes these are? Posted: Aug Sun 18, 2019 4:30 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 9354 Location: Beaver Falls, PA. USA
If the white deposit is inside the tube, it's a dud.
_________________ Tim KA3JRT
Top |
Peter Bertini
Post subject: Re: Any idea what type of tubes these are? Posted: Aug Sun 18, 2019 6:30 pm |
Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 23213 Location: Somers, CT
That style tube was usually not flash gettered, the plate was impregnated with a gettering agent.
_________________ Just because it can be done doesn't mean it should be done.
Top |
Page 1 of 1
[ 13 posts ] |
