It is currently Jul Mon 06, 2020 1:55 pm
 Post subject: Multi can capacitor question
PostPosted: Aug Sun 18, 2019 1:43 am
I have a Robyn CB radio that I believe the multi can capacitor is bad in. There is a 220k resistor hooked to it that fried. I put in a new resistor and it heated up and burnt in seconds.
The multi can is a:
350v. 47uf
350v. 47uf
350v 47uf
1) how do I test it?
2) if bad we’re can I get one?
3).If I can’t find one can I use a:
350v 50uf
350v. 50uf
350v. 50uf
 Post subject: Re: Multi can capacitor question
PostPosted: Aug Sun 18, 2019 2:19 am
Schematic or model number?
Eddy
PostPosted: Aug Sun 18, 2019 3:17 am
If it cooked that 220K resistor, there may be some additional issues wrong with it, than just some bad caps. Normally, 47 & 50 are more than close enough, but the other possible issues with it need to be resolved, too.
A model number would be nice, so we can look up the circuit, and give better guidance.
The power rating on that 220K as the same or higher than the original ? If a 1/4W was used in place of a 2W, it won't live long.
Life is like a roll of toilet paper - The closer you get the end, the faster it goes - A.E. Neuman
PostPosted: Aug Sun 18, 2019 4:19 pm
You can replace the single can with three separate capacitors of those values.
Tim
PostPosted: Aug Sun 18, 2019 6:18 pm
Yes, that is the way most often is done. Multiple value can caps aren't available, so individual caps are now used.
Hopefully there is enough room to install them.
47 @ 350 is a common value. or you could use 47 @ 450 if that's all you have.
PostPosted: Aug Mon 19, 2019 6:28 am
Interesting. You'd have to have more than 235 volts across a 220k 1/4W resistor to fry it. Maybe this was a power supply discharge resistor.
PostPosted: Aug Tue 20, 2019 6:17 am
Multiple caps in one can are still available, but pretty expensive.
https://hayseedhamfest.com/collections/all
PostPosted: Aug Mon 26, 2019 3:35 pm
Don't replace it with another NOS can, use new 47 caps.
PostPosted: Aug Mon 26, 2019 3:43 pm
Interesting, those Hayseed Hamfest Capacitors. Obviously stuffing new caps in reproduction cans!
I'll have to keep them in mind, thanks! :D
PostPosted: Aug Tue 27, 2019 12:59 am
I have been using capacitors from Hayseed for several years, on vintage audio equipment. He's not cheap, but the caps fit perfectly; both in capacity and physical mounting.
In the "good old days", Sprague and Mallory had dozens of exact replacement can caps in their catalogs.
PostPosted: Sep Sun 01, 2019 7:11 am
Maybe I'm missing something in this thread, but multi section can capacitors are available. I just built a MEQ-5 clone using two brand new CE Mfg. multi section can caps sourced from Antique Electronics Supply ( https://www.tubesandmore.com/products/c ... Can%20Type ), but I'm aware of other sources too.
Additionally, I had Hayseed Hamfest make a 2.0uF can for the same build that works and looks as specified. Maybe Hayseed is playing loose with their terminology or being secretive, but I was told that they are not stuffing their cans. Even if they are stuffing in any way, for this build I prefer the vintage look understanding that I'm paying extra just for looks over just plugging in a compatible off the shelf dipped variant from Mouser or wherever.
~ Greg
PostPosted: Sep Sun 01, 2019 3:51 pm
JJ makes a whole line of multi section electrolytic capacitors. You do need to use a clamp for replacement if you originally had an "FP" type "Twist-Lock" capacitor. I have never had an issue with using them. They make enough variations that you would be able to restore a vacuum tube amplifier easily. The only negative observation that I have is that most of the clamps that you buy are extremely flimsy. It's good to save vintage USA manufactured clamps for them.
PostPosted: Sep Sun 01, 2019 4:00 pm
Not to blubber on but here is a pair of JJ Electrolytic Capacitors and below them is a 4-section capacitor. The 4-section one is less than $15 at AES and I checked the auction site and they want $20 for them!
PostPosted: Sep Sun 01, 2019 11:25 pm
I can rebuild a can with no visible evidence, cut with a big butcher knife rolling the can on a rubber mat.
PostPosted: Sep Mon 02, 2019 4:03 pm
I rebuild them too but I usually un-crimp the edge so that I don't have to epoxy them back together. Yes, it is time consuming but it pleases me to do it that way. There are many ways to rebuild them and we have many talented members who have shared their talent.
Users browsing this forum: Chas and 8 guests
