Page 1 of 1
[ 10 posts ] |
Author |
criageek
Post subject: Need Info For Airline Record Changer Posted: Sep Mon 09, 2019 4:52 pm |
Joined: Mar Thu 02, 2017 1:37 am Posts: 704 Location: Cedar Rapids, Iowa
I am working on this radio for a customer: Attachment:
Oddly enough I have not been able to find a model number anywhere. Here is the label on the bottom: Attachment:
Based on the info I've found on RadioMuseum ( https://www.radiomuseum.org/r/montgomery_84wg2015b.html) I believe it's either an 84WG-2015A or 84WG-2015B. I'm pretty sure I can handle the electrical restoration but I haven't found anything about the record player so I'm hoping someone can help me out, either with some documentation, or just general info. This label is also on the bottom of the cabinet: Attachment:
So I think the record changer is model number 148-2. My preferred method for restoring these things is to disassemble them completely, clean and lubricate, and reassemble. But I'm going in somewhat blind on this one and need to be sure I can do the last step (reassemble) correctly. Here are a couple of pics of the record changer: Attachment:
Any help out there? Thanks! Rich
_________________ My name is not Craig...look closely. cr = Cedar Rapids, ia - Iowa, geek = geek
Top |
Hotwax
Post subject: Re: Need Info For Airline Record Changer Posted: Sep Mon 09, 2019 5:31 pm |
Joined: Jan Wed 16, 2013 12:04 am Posts: 2152 Location: 77001
Hi Rich, Here's a link also from radio museum with the Webster-Chicago model 148 Rider's reference Volume 18. The page also gives a SAMS Photofact Vol.9/50 Date 2-50 Set 86 Folder 12. Rider's can be found for free on the internet. Let us know how the restoration goes. Hotwax https://www.radiomuseum.org/r/webster_148.html
Top |
criageek
Post subject: Re: Need Info For Airline Record Changer Posted: Sep Mon 09, 2019 5:54 pm |
Beautiful! Sorry, I should have been smart enough to look under Webster-Chicago, but thanks for steering me in the right direction. That's some great info. I got anxious and went ahead with the disassembly before seeing this, but took tons of pictures and this info will help immensely when it comes time to reassemble.
Thanks!
Top |
criageek
Post subject: Re: Need Info For Airline Record Changer Posted: Sep Tue 10, 2019 2:27 am |
Disassembly is nearly complete, cleaning is nearly complete, and reassembly has begun. But I'm having problems removing the main cam from its shaft...the circular part in this photo: Attachment:
The grease has completely dried out and is acting like cement. I've been applying lacquer thinner to both ends in hopes that it would eventually work it's way down the shaft and loosen it up. I'll continue this process unless someone can suggest a better method. Would I be better off using WD-40 or penetrating fluid? How about heat? Would that soften it, or would that just lock it on tighter? Thanks! Rich
Top |
Hotwax
Post subject: Re: Need Info For Airline Record Changer Posted: Sep Tue 10, 2019 3:55 am |
criageek wrote: The grease has completely dried out and is acting like cement. I've been applying lacquer thinner to both ends in hopes that it would eventually work it's way down the shaft and loosen it up. I'll continue this process unless someone can suggest a better method. Would I be better off using WD-40 or penetrating fluid? How about heat? Would that soften it, or would that just lock it on tighter? I have applied ZoomSpout turbine oil to penetrate, then I used a long-tipped butane lighter to heat up the metal. This was done on some 1970's BSR changers that invariably have the cam wheel cemented by the old British "epoxy" grease. Sometime it took several attempts with heat to release. So, I believe heat will eventually work on this project, as long as the parts are all metal. Hotwax
Top |
criageek
Post subject: Re: Need Info For Airline Record Changer Posted: Sep Tue 10, 2019 12:41 pm |
Thanks Hotwax...I'll try a heat gun later on. For lubrication, the manual calls out the following: No. 10 oil - I have some 3-In-1 oil I can use Lubriplate - When restoring a jukebox last year I found a recommendation for using "Sta-Lube SL3141 Moly-Graph Extreme Pressure Multi-Purpose Lithium Grease" ( https://www.amazon.com/gp/product/B000C ... UTF8&psc=1) in place of Lubriplate since it is no longer available. Sta-Put - I'm not sure what to use here. I see Sta-Put is available but it looks like there is a variety to choose from. They call for it to be used here: Teeth of main cam actuating gear Track of main cam gear Teeth of large and small idler gears Raising lever bracket bearing surfaces Any recommendations for what type of lubricant to use in these places? Thanks! Rich
Top |
Hotwax
Post subject: Re: Need Info For Airline Record Changer Posted: Sep Tue 10, 2019 2:22 pm |
RE: Lubrication.
Some time back on ARF, I was recommended Super Lube multi-purpose synthetic grease.
I have used it since, and it is a good product, and not costly.
Should be available for purchase most anywhere. Hotwax
Top |
Tommgb
Post subject: Re: Need Info For Airline Record Changer Posted: Sep Wed 11, 2019 12:52 am |
Joined: May Mon 30, 2011 10:12 pm Posts: 1513 Location: Glendale, CA
I've used Super Lube with great success. I found mine at Harbor Freight. With my 20% off coupon, it cost me $5.59.
_________________ "A challenge to be met, rather than an obstacle to avoid." - Mr. Data
Top |
NumberMaj 1
Post subject: Re: Need Info For Airline Record Changer Posted: Sep Wed 11, 2019 3:57 pm |
Joined: May Sat 06, 2006 4:03 am Posts: 3606 Location: ZIP 23831 South of Richmond, VA 25 miles down the pike.
Have you tried removing the screw?
Bill J.
Attachments: |
Top |
criageek
Post subject: Re: Need Info For Airline Record Changer Posted: Sep Thu 12, 2019 1:29 am |
Thanks guys! A little heat, and off it came: Attachment:
My local Ace Hardware had some Super Lube in stock so I stopped by to pick up a tube, but they wanted $9.69. So I drove across town to the Harbor Freight and picked up a tube for $5.59 after 20% discount...thanks Tom! The shaft was sightly loose, possibly from me trying to remove the cam. So I cleaned up the area with some sandpaper, followed by alcohol. Attachment:
I make my own golf clubs so I mixed up some shafting epoxy to glue it in place. Attachment:
I designed and printed a clamp on the 3D printer to 1) hold the shaft steady, and 2) make sure it was vertical. Attachment:
It'll probably be Friday before I can continue reassembling, but it's moving along! Bill - the screw is just there to make sure I don't lose it and I know where it goes. It does not hold the cam on the shaft...it's for mounting the sub-plate to the main phono chassis. Rich
Top |
Users browsing this forum: No registered users and 6 guests |
