It is currently Apr Thu 09, 2020 4:02 am
 Post subject: Admiral 19A11SN
PostPosted: Sep Mon 09, 2019 10:56 pm
Picked up an Admiral Model 19A11SN tv with a 7JP4 tube, circa 1948. I found out that power transformer chassis were top of the line but I will stick to repairing radios. Can bring to Kutztown if interested in restoring.
 Post subject: Re: Admiral 19A11SN
PostPosted: Sep Wed 11, 2019 7:34 pm
That's a classic '40's TV and definitely one of the better 7 inch compact TV's. Admirals at that time were all very good. Even though that model had a power transformer, it was still priced around $179 like the many others were. Those CRT's, when tested good, are getting harder to find and worth $100-$150 alone.
PostPosted: Sep Wed 11, 2019 7:52 pm
Thanks. That was the information I was after.
PostPosted: Sep Wed 11, 2019 8:18 pm
You're welcome. A big plus with them is having the original cardboard back, channel plate that's not badly warped, and it's original correct knobs. Of course no cracks. Other than a minor hairline in a non-conspicuous area, a serious one will destroy it's value.
PostPosted: Sep Wed 11, 2019 11:55 pm
This one has a crack along the top and bottom seam of the cabinet but when epoxied should not show. Has one original knob. Everything else looks ok.
PostPosted: Sep Thu 12, 2019 12:26 am
If the crack can be epoxied right at a seam it will not destroy the sets value, but it does hurt it quite a bit. The "waffle" pattern knobs aren't very easy to come across, so that effects the value too. I would say a very good, clean, complete set, unrestored, with an untested CRT, would sell for $150-$175, so you can price it accordingly.
PostPosted: Sep Thu 12, 2019 1:06 pm
Once again thanks for the information. I guessed at a value of $50 but apparently off quite a bit. I am wondering if I should test the CRT for filament continuity since that is the main driver of the value for this TV?
PostPosted: Sep Thu 12, 2019 4:18 pm
The most 7JP4s die of cathode surface depletion not heater issues.
PostPosted: Sep Thu 12, 2019 4:53 pm
The bottom line is that if the CRT tests very good, then that will be most almost all of the sets value. I hate to say it, but in that case you'd be better off parting it out. Being tested, you could get over $100-$150 for the CRT. The chassis, and CRT mask, might get a few bucks, but not much. The cracked cabinet is of very low value. Selling it all together for $50 or more will likely scare most buyers away.
PostPosted: Sep Thu 12, 2019 5:40 pm
Thanks. I have no problem parting it out. Certainly a lot easier to ship that way.
PostPosted: Sep Thu 12, 2019 6:17 pm
just checked pins 1 and 14 and filament has continuity. there is a 7JP4 on ebay right now for $103.80.
Post New Topic Post Reply  [ 11 posts ]  Moderators: 7jp4-guy, Mr. Detrola
Users browsing this forum: Pearson and 5 guests
