Page 1 of 1
[ 11 posts ] |
Author |
Radiotiques
Post subject: Admiral 19A11SN Posted: Sep Mon 09, 2019 10:56 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 920 Location: Wilmington DE USA
Picked up an Admiral Model 19A11SN tv with a 7JP4 tube, circa 1948. I found out that power transformer chassis were top of the line but I will stick to repairing radios. Can bring to Kutztown if interested in restoring.
Top |
decojoe67
Post subject: Re: Admiral 19A11SN Posted: Sep Wed 11, 2019 7:34 pm |
Member |
Joined: Feb Thu 17, 2011 11:27 pm Posts: 13217 Location: Long Island, N.Y.
That's a classic '40's TV and definitely one of the better 7 inch compact TV's. Admirals at that time were all very good. Even though that model had a power transformer, it was still priced around $179 like the many others were. Those CRT's, when tested good, are getting harder to find and worth $100-$150 alone.
Top |
Radiotiques
Post subject: Re: Admiral 19A11SN Posted: Sep Wed 11, 2019 7:52 pm |
Thanks. That was the information I was after.
Top |
decojoe67
Post subject: Re: Admiral 19A11SN Posted: Sep Wed 11, 2019 8:18 pm |
Member |
Radiotiques wrote: Thanks. That was the information I was after. You're welcome. A big plus with them is having the original cardboard back, channel plate that's not badly warped, and it's original correct knobs. Of course no cracks. Other than a minor hairline in a non-conspicuous area, a serious one will destroy it's value.
Top |
Radiotiques
Post subject: Re: Admiral 19A11SN Posted: Sep Wed 11, 2019 11:55 pm |
This one has a crack along the top and bottom seam of the cabinet but when epoxied should not show. Has one original knob. Everything else looks ok.
Top |
decojoe67
Post subject: Re: Admiral 19A11SN Posted: Sep Thu 12, 2019 12:26 am |
Member |
Radiotiques wrote: This one has a crack along the top and bottom seam of the cabinet but when epoxied should not show. Has one original knob. Everything else looks ok. If the crack can be epoxied right at a seam it will not destroy the sets value, but it does hurt it quite a bit. The "waffle" pattern knobs aren't very easy to come across, so that effects the value too. I would say a very good, clean, complete set, unrestored, with an untested CRT, would sell for $150-$175, so you can price it accordingly.
Top |
Radiotiques
Post subject: Re: Admiral 19A11SN Posted: Sep Thu 12, 2019 1:06 pm |
Once again thanks for the information. I guessed at a value of $50 but apparently off quite a bit. I am wondering if I should test the CRT for filament continuity since that is the main driver of the value for this TV?
Top |
Electronic Memory
Post subject: Re: Admiral 19A11SN Posted: Sep Thu 12, 2019 4:18 pm |
Member |
Joined: Nov Thu 11, 2010 6:03 pm Posts: 966 Location: Pewaukee, WI
The most 7JP4s die of cathode surface depletion not heater issues.
Top |
decojoe67
Post subject: Re: Admiral 19A11SN Posted: Sep Thu 12, 2019 4:53 pm |
Member |
The bottom line is that if the CRT tests very good, then that will be most almost all of the sets value. I hate to say it, but in that case you'd be better off parting it out. Being tested, you could get over $100-$150 for the CRT. The chassis, and CRT mask, might get a few bucks, but not much. The cracked cabinet is of very low value. Selling it all together for $50 or more will likely scare most buyers away.
Top |
Radiotiques
Post subject: Re: Admiral 19A11SN Posted: Sep Thu 12, 2019 5:40 pm |
Thanks. I have no problem parting it out. Certainly a lot easier to ship that way.
Top |
Radiotiques
Post subject: Re: Admiral 19A11SN Posted: Sep Thu 12, 2019 6:17 pm |
just checked pins 1 and 14 and filament has continuity. there is a 7JP4 on ebay right now for $103.80.
Top |
Users browsing this forum: No registered users and 1 guest |
