It is currently Dec Wed 01, 2021 4:58 pm
 Post subject: Pioneer SX-1000TW FM Tuner Errors
PostPosted: Oct Fri 18, 2019 7:37 pm
Pioneer SX-1000TW
FM Stereo Receiver - FET in the FM radio frequency amplifier stage design.
Only During FM Recieve do I hear Loud Popping ( similar to Receive Atmospheric Static Crashes ) occansionally , more predominant after unit major warn-up. This Popping Does Not Occur During Auxiliary Equipment ( CD Player ) Playback and do not notice during AM Broadcast.
Secondly - FM Recieve Audio will ( less occansionally ) drop Audio total output for a millisecond - very spuradic.
Question - Looking for suggestions.
The sound appears to be a Capacitor Defect - very spuradic.
Will completing a Full FM Tuner Alignment Solve These Two Problems or Should I Troubleshoot and try to chase these two errors ?
Your suggestions.
cferry1
 Post subject: Re: Pioneer SX-1000TW FM Tuner Errors
PostPosted: Oct Fri 18, 2019 10:49 pm
Have you the experience of replacing the electrolytic capacitors in a 1970s receiver like this before?
Service manuals...
http://www.kallhovde.com/pioneer/sx-1000tw-om-sm.pdf
http://www.kallhovde.com/pioneer/sx-1000ws.pdf
Stay away from an alignment.
:) Greg.
PostPosted: Oct Sat 19, 2019 3:27 pm
Yes.
I could replace the Electrolytic Capacitors.
However, I am concerned that the error is only during FM Receive Operation.
PostPosted: Oct Sun 20, 2019 8:30 am
If you don't want to replace the electrolytics, try poking components with a plastic chopstick and see if you can locate a dry solder joint.
Also, a close visual inspection of the components will often yield results. Look for signs of overheating - burnt or near burnt.
FM boards are shown in the service manual.
Take note: When poking around a live chassis with chopsticks or the likes, keep your less dominant hand in your back pocket.
This is to stop electricity traveling up one arm and through your chest (heart) and out the other arm.
Otherwise... pull the boards and replace the electrolytics as a first step.
Wire wrapping tools can be found on ebay.
https://www.ebay.com/sch/i.html?_from=R ... 0&_sacat=0
Clean the posts and wire ends with some IPA before re-wrapping.
Use capacitors rated at 35V or 50V (for 6.3V 10V 16V 35V) and 105°C temperature rating.
If the traces begin to lift, your iron is not hot enough - you want to get in-and-out quickly.
Modern day electrolytic capacitors have become so much smaller since the 1960s and '70s
Some of the old μF (microfard) values are no longer common... so choose the next nearest capacitance value, up or down.
... I buy the 50V ones today to replace the old 3V, 6V + 10V
fyi... electrolyitc capacitors rated as 85°C are good enough for transistor radios.
It's foolish to hunt down 3V 6V or 7V electrolytics.
I mark their negative connection on the circuit board with a sharpie and... replace them one at a time, otherwise you can get confused.
For my money, Panasonic... 105°C
FC series
FM series
FR series are all good capacitors.
Before and after soldering...
I clean (and dry) with IPA (isopropyl alcohol) using a small acid brush or an old toothbrush. I use 70% (strength) isopropyl alcohol... mixed 50/50 with regular nail varnish remover (acetone), it leaves no residue.
In a past life I have used Zippo lighter fluid (naphtha) or denatured alcohol in a pinch.
More applicable to modern-day devices...
Adding lead solder to a lead-free soldered joint speeds up the removal process. It lowers the melting point.
If you haven't got a solder sucker...
.. EDSYN DS017 DELUXE SOLDAPULLT
...use fresh solder-wick. (The outer braid of TV coax can be used to soak up the old solder if you are in a jam).
Create a shopping-list... BOM (bill of materials) and post it here for verification, if you wish.
:) Greg.
Edit: the large (snap-in) filter capacitors may be difficult to locate nowadays.
You can replace them with regular through-hole radial ones as seen here.
(no pun intended) lol
PostPosted: Oct Wed 23, 2019 12:08 pm
A few thoughts: Don't bother trying an FM alignment for this type of problem... it can only hurt you. I'd also not try a major capacitor overhaul just yet. You might be able to isolate the problem to an area of a board (the FM tuner most likely) by using a hair dryer on low heat, then on just air, to heat/cool certain components. As you get closer, freeze spray can narrow it down to a single part or solder joint. For spot heating, you can just hold a soldering iron CLOSE to a suspect part to heat it up a bit.
From your description, the problem has some connection to heat, so it should be fairly simple to localize this way. Going on a capacitor jihad will introduce a few hundred other variables... I'd hold off on that for now.
PostPosted: Oct Wed 23, 2019 12:24 pm
Ask 10 people and get.........
A few years ago, I overhauled THREE Pioneer receivers from the 70s. After a bit of reading about electrolytics from that era, I decided on the "shotgun" approach-----ALL electrolytics were replaced before power-on. Also, all the other typical inspection of solder joints, checking resistors, etc.
All three sets worked perfectly after all this + alignment.
I don't remember if I had wire-wrap in those three---or somewhere else. Regardless, If I find 50 year old wire-wrap joints, they get soldered.
PostPosted: Oct Wed 23, 2019 12:29 pm
roll the dice. :). Sometimes it comes up 11, sometimes snake eyes. :shock:
PostPosted: Oct Wed 23, 2019 12:52 pm
I have been mostly successful with the "shotgun" method, but I certainly don't advocate it for everyone. I'll spare you the gory details of the cases where 20:20 hindsight suggested a different approach....:)
PostPosted: Oct Wed 23, 2019 1:03 pm
I hear ya .... I suppose if I were selling or keeping vintage (70s) stereo equipment it might be different. But all I'm doing right now is acting as a hired gun for a local stereo shop. For basically beer money lol. The marching orders are "just fix it" .... so restorations that involve replacing 100 capacitors are out of the question. All the customer wants is it 'fixed' so I swallow hard, and just fix it.
I completely agree however, that the shotgun approach is definitely not for everyone. The novice would be much better served to first get their system working, and THEN start wholescale capacitor replacements where they can check it as they go, basically. To be successful at the shotgun approach, you'd have to assume that the one doing the work is capable of finding any errors that they introduce, such as a wrong value electrolytic, one installed backwards, some wire broken etc ..... and that's a stretch for most begineers. misspelled, but it looks like it fits. I invented a new word (beginner engineers = begineers)
PostPosted: Oct Wed 23, 2019 1:22 pm
10 years ago, I had no intention of trying to fix electronics for customers. After moving to the DC/Baltimore/Annapolis sprawl, I discovered a significant demand, and restoration jobs trickle in regularly. The best jpbs are the sets that have been in the family for some time and are being fixed for their nostalgic value. I don't accept any work other than a complete refurbishment and, so far, I'm getting away with it.
Remembering the 100s of little electrolytics in those Pioneers, I wondering how that episode compares to the German sets that come in regularly. Sometimes I wonder if I'm the only one around here that will take on a German radio......that doesn't seem plausible
PostPosted: Oct Wed 23, 2019 3:42 pm
^5 to that ..... I had no intention of ever getting back into HiFi service either... so much for the best laid plans. But now I have the first right of refusal ... I can REFUSE if I want lol. And I will, if it stops being fun. I kinda like that they don't do restorations on these.... they limit that to what we do here on the forum... namely vintage tube stuff. He's got a tech there that handles that stuff. Fine with me. Most of it is huge living room furniture size consoles etc which I'd turn down anyway.
And first and foremost, I do NOT have to deal directly with the customer. That is worth a lot of $$$ to me ... been there, done that, won't again.
So I replace the fried power supply pass transistor, a few caps, and a few panel lamps, and move on to the next one. Occasionally an output stage. So far, none beyond repair. Some of these things are selling for $1,500 - $2,000 so I probably could make a good buck restoring them if I were so inclined. I am definitely NOT so inclined. I've got a warehouse full of antique tube type test gear calling me ....
:D 8) !!!
PostPosted: Sep Thu 23, 2021 7:05 am
pixellany wrote:
[quote="Barry H Bennett"I don't accept any work other than a complete refurbishment
Time passes and it seems to me that apart from collectors, no one uses old radios for their intended purpose. Therefore, only repairs seem to me questionable. Previously, repairmen did repair work. And if he immediately changes all the capacitors, then who then will come to him after a short time to change the next capacitor in the same radio? ))
I had a case where I only changed obviously bad capacitors. It turned out the "good" ones were also bad and it cost me a lot of time to find the reason for the poor radio performance. Now only a complete replacement of all electrolytic capacitors at once.
i'm not sad i'm sober
PostPosted: Sep Thu 23, 2021 7:39 am
A few thoughts: Don't bother trying an FM alignment for this type of problem... it can only hurt you. I.
+1 - this certainly doesn't seem like an alignment problem and unless you know exactly what you are doing, the chances of screwing it up are far higher that the chances that it drifted in alignment to any great degree.
Intermittents (wire wrap or otherwise) are certainly possible, but my money would be on electrolytic capacitors, in this case, either shorting or arcing internally, or so down on capacity that whatever they are there to filter out or stabilize is not being filtered out or going unstable. I haven't worked on a large number of this era Japanese components, but all those I have, all of them had multiple bad electrolytic capacitors (several in addition to other, larger, problems).
Switches and pots are also a good place to look, they rarely fail outright but oxidizing and getting dirty is nearly universal, and these parts (usually from ALPs in a small form factor) seem to be disproportionally prone to getting dirty. Before you do anything with a soldering iron, thoroughly clean every pot and switch with a non-residue electronic parts cleaner, test, then go over with a small amount of lubricating cleaner (DeOxit D5 or FaderLube). Then see if you still have a problem.
Brett
PostPosted: Sep Thu 23, 2021 8:54 am
Sep 2021 answers to Oct 2019 problems. :(
And the OP never came back, either. :roll:
PostPosted: Sep Thu 23, 2021 9:54 am
The problem only gets worse over the years :mrgreen:
PostPosted: Sep Thu 23, 2021 12:29 pm
LOL yea, another of those disappearing OP threads ...... wonder if they ever fixed it :)
PostPosted: Sep Thu 23, 2021 12:36 pm
I imagined how all the old rubbish and the services of those who know at least something in technology will rise in price if the post-apocalypse does happen. Sometimes I seriously think about how to save all this volume of information from the Internet, if it also ends up sometime ...
PostPosted: Sep Fri 24, 2021 7:59 pm
We give the information we have, and whether or not the OP uses it, lots of people read these things, so it is not wasted effort.
These sorts of forums encourage both thread drift and answers directed to the lurkers. That is not a defect. While I would love to know if it all got fixed, a strictly "question" and "answer" (no side trips) would lose *a lot* of the content. thread drift in particular usually results in very interesting and informative discussion whether or not the original question gets answered.
And, after 30ish years of these sorts of forums (as long as they have existed, not just ARF), one of the most annoying of all posting type is the accursed "thread manager", where someone take it upon himself to tell people to " get back on topic, please" because other people are having a discussion not directed specifically towards his problem. Once someone posts something in public, *it is not their personal thread anymore*, it is everyone involved's thread. Fortunately we have very few, if any, of these loathsome characters on ARF, but they are pretty common in other hobby forums. The few we had didn't last too long.
Brett
PostPosted: Sep Fri 24, 2021 9:03 pm
hmmm.... does that thread drift include an OP question on FM tuner alignment that morphs into 2 stroke engine maintenance I wonder ? Personally, I find that distracting to say the least ;-) Sure, it's well within the forum rules, and perhaps someone is really benefiting from 2 stroke engine maintenance theory .... but <ahem> doesn't that belong in a 2 stroke engine thread perhaps ? :mrgreen:
