You're Knight tube tester shown is a 83YX143 there is a manual at:
https://www.radiomuseum.org/r/allied_ra ... yx143.htmlThe 83yx143 differ than later 600
The Triplett 2413 and 3413 is what the Knight Kit Tube Testers are base on, in fact Triplett made
some of the or all Knight Kit tube testers.
From a number of posts it has become apparent that the roll chart or charts for the Triplett 3413, EICO 625, Heathkit TC & IT and Knight 600 (all simple emission testers) have the same settings for the tubes but may have, as pointed out in one of the posts, different switch configuration. I believe the the Knight used letters as opposed to numbers for the switches which correspond to the pin numbers of the tubes (9 & 10 on the EICO being grid caps). The columns for the tube chart (and switch settings) are "Tube Shunt Fil Sel Up Down". The Up, Center and Down on the pin switches are Center position = Filament Voltage, Down = Common (Gnd/0 V.) and Up = Positive DC V. On other models, if you know which position equals the above on your unit, you can interpolated the settings to suit the unit.
