It is currently Jan Wed 26, 2022 6:46 pm
 Post subject: Power for 6-volt battery sets
PostPosted: Jan Tue 12, 2021 2:24 pm
Hi all,
I was just reading another topic concerning "farm radios", where it was stated that the power supplies required for them are cumbersome. This is quite true for those with 6.3-volt "A" battery and a vibrator. On my sets with this type of power requirement I simply install a wire to the B+ supply point in the circuit. Then I pull the vibrator out and use my AES power supply to provide A and B voltages to the set. It saves the vibrator from wear, operation is nice and quiet and the power supply required is bulk-free. When I decide to play a set from a storage battery, I put a wire nut on the B+ wire and stow it away, pop in the vibrator and let her hum back to life!
 Post subject: Re: Power for 6-volt battery sets
PostPosted: Jan Tue 12, 2021 3:38 pm
Chuck Braun wrote:
Hi all,
Smart Move! That is one modification I can rave about. Most of these "farm radios" require a 60ah lead battery to provide the 'nads to kick over the vibrator then substantial current just to hum. A plus is the AES supply is about as economical as it gets...
Kudos on good idea! chas
PostPosted: Jan Tue 12, 2021 7:51 pm
And another plus to this method is that you can play these sets all day on a 6-volt lantern battery with a clip of ten 9-volt batteries for the "B" supply...
PostPosted: Jan Tue 12, 2021 11:54 pm
Wow, looks like a great work-around for the amp intensive 6 volt farm sets. I'll have to give it a try on one of my Zeniths, thx!
